909 Posted April 8, 2008 Report Posted April 8, 2008 I've been looking for internal photos of the Reimyo CDP-777 since the thought first entered my mind that I might own one. Over the past 11 months when the occasion presented itself, I have done numerous in depth searches for such images, but to no avail. so as far as I know, these are the first internal pictures posted on the net. enjoy the gut pics of my CDP777... Quote
HiWire Posted April 9, 2008 Report Posted April 9, 2008 Thanks! These will probably be especially useful to those who can understand what they are looking at... Quote
909 Posted April 9, 2008 Author Report Posted April 9, 2008 Thanks! These will probably be especially useful to those who can understand what they are looking at... QFT Nice colors! i like the pretty different colored wires. in fact, in certain locations it's like little wire rainbow arrangements. Quote
spritzer Posted April 9, 2008 Report Posted April 9, 2008 Nice pictures but the player could use some work... What the hell is that internal optical cable seen in the second to last picture connected to? It looks like it is connected to the back of the transport (third picture) but that is just wrong on so many levels if it is feeding the dacs... Quote
909 Posted April 9, 2008 Author Report Posted April 9, 2008 there's no optical outputs on the player so optical is likely feeding the dacs (or some sort of combo of things unseen at that vantage-point) at least that's what we thought, but we also assumed there's more going on underneath on the board's bottom side. if it's wrong, wrong never sounded so right Quote
luvdunhill Posted April 9, 2008 Report Posted April 9, 2008 what is the part number on the BB chips in the last picture, near the output coupling caps (i.e. IC727)? There are four of them. Opamps / Buffers perhaps? Quote
Pars Posted April 9, 2008 Report Posted April 9, 2008 Nice pictures but the player could use some work... What the hell is that internal optical cable seen in the second to last picture connected to? It looks like it is connected to the back of the transport (third picture) but that is just wrong on so many levels if it is feeding the dacs... Sure that isn't 75 ohm coax connecting the SPDIF output on the back? In which case, that is the right way to do it assuming transformer and interface is done correctly also... Quote
spritzer Posted April 9, 2008 Report Posted April 9, 2008 Sure that isn't 75 ohm coax connecting the SPDIF output on the back? In which case, that is the right way to do it assuming transformer and interface is done correctly also... You can see the part name on the back in the second to last picture (RX176) and that is Toslink receiver. Further to the right you can see a transmitter as well and both are facing the transport area... Quote
Pars Posted April 9, 2008 Report Posted April 9, 2008 Sorry, on my work windoze machine... can't see the pics that well. Internal toslink... wtf?? Why not use I2S? Quote
luvdunhill Posted April 9, 2008 Report Posted April 9, 2008 Sorry, on my work windoze machine... can't see the pics that well. Internal toslink... wtf?? Why not use I2S? probably they were forced to, due the massive amount of power lines in that general vicinity. Quote
justin Posted April 9, 2008 Report Posted April 9, 2008 Sorry, on my work windoze machine... can't see the pics that well. Internal toslink... wtf?? Why not use I2S? I don't think it's SPDIF, I see at least 2 optical connections Quote
cclragnarok Posted April 9, 2008 Report Posted April 9, 2008 I don't think it's SPDIF, I see at least 2 optical connections Maybe the input clock and DAC clock are separated using some sort of a buffer, and the second optical is used for feedback rate control? Then it wouldn't matter whether or not TOSLINK is used to transfer the data. Quote
spritzer Posted April 9, 2008 Report Posted April 9, 2008 I don't think it's SPDIF, I see at least 2 optical connections Why not use ST then? It's definitely a toslink receiver that feeds the DAC but where the other one is going is hard to tell as it is a transmitter. It could be that the JVC drive can only output S/PDIF but a coax cable would be an even better solution. Quote
justin Posted April 9, 2008 Report Posted April 9, 2008 The Japanese Victor Company (JVC) supplies the mathematical and physical heart of the CDP-777: K2 digital processing as used in their acclaimed XRCD compact discs (Reimyo uses the Extended Version 2.0 form), delivering 176.4 kHz/24-bit performance with an effective data rate in excess of 700 kHz with 4x oversampling. Components of the K2 Interface The K2 Interface has three major features: Quote
luvdunhill Posted April 9, 2008 Report Posted April 9, 2008 so basically, it's used for galvanized isolation. Quote
spritzer Posted April 9, 2008 Report Posted April 9, 2008 That explains it but it's still a strange way to do it as many digital components use transformers on the digital line to do just that. It could also be because the drive was designed as a stand alone transport to feed a clock linked dac in the studio and thus making it simpler to build. Quote
909 Posted April 9, 2008 Author Report Posted April 9, 2008 It could also be because the drive was designed as a stand alone transport to feed a clock linked dac in the studio and thus making it simpler to build. yes, it has an external sync-in (for the clock) and digital output--my friend is a composer and he's looking to buy one after hearing most of the big hitters and mentioned that the cdp777 transport could be linked up (big ben i believe) to used in his studio system. Quote
luvdunhill Posted April 9, 2008 Report Posted April 9, 2008 yes, it has an external sync-in (for the clock) and digital output--my friend is a composer and he's looking to buy one after hearing most of the big hitters and mentioned that the cdp777 transport could be linked up (big ben i believe) to used in his studio system. hey, did you get the numbers off those chips? Just curious if they're BB INAxxx devices. Quote
909 Posted April 11, 2008 Author Report Posted April 11, 2008 based off the pics and what a good friend said i think you're referencing the OPA627AP, the other 4 op-amps which are probably the I/V conversion look like they're covered by black stuff. Quote
909 Posted April 16, 2008 Author Report Posted April 16, 2008 apparently, the 4 op-amps aren't covered with black goop. a very knowledgeable fellow that actually looked at the reimyo guts with a magnifying glass said they are custom made op-amps--not off the shelf stuff. Quote
