With my feel HP 200SE tube mosfet hybrid amp, whenever I have my headphones pugged into the low gain jack, every now and again the left channel fades out to a whisper. If I turn the amp off and then turn it back on it corrects itself and won't fade out again that listening session. I know that amps are complex but is there an obvious reason why this would be happening?
Has Jacob ever used, looked at, or even heard about your amp?
ZOMG! I think he did! Well I think incineration may be the only thing to do now.
But anyway, I swapped left and right channels so we'll see if the right side fades anytime soon...
This makes me wish I knew anything about tubes.
Well it's been on for more than 10 minutes and it always fades out before then so that's a good sign. It doesn't happen every time so there still is a good chance that it will screw up in the next week.
From my own experience what has caused that is a tube socket losing connection. Once the amp gets hot enough, the connection is lost. You can try changing tubes and see if that alleviates the problem.
Biggie.
Read: haunted tube sockets.
Biggie.
Interesting however that wouldn't account for the fact that when I turn it off and then immediately turn it back on the left channel comes back for the rest of the listening session. I think JBLoud's answer of my amp being haunted is the most logical. Perhaps a haunted amp could fetch quite a price if I advertise it as such on Ebay.
Yeah you'll make a few g's off a haunted amp. I wish I had one.
I am pretty thankful that it is just a tube. Considering that there is absolutely no chance of getting this amp repaired if something major does go wrong with it. However, for $300 this amp has been the best addition to my rig with out question.
That's happened to me twice, with 2 different Tung-Sol 6sn7 tubes - the expensive kind :rant:
It was the right triode heater that went out in both cases. One of them tested and played OK afterwards (in a different amp), which is consistent with your tube showing life after death. Haven't used it again, though. The other tube never came back.
