Have you checked the reviews section at iLounge. I find their rating system to be pretty tough, with only good products getting A's a good, but more specific use products in the B range (marked down for price or lack of some functionality).
Thanks you two. I did run through nearly all of iLounges reviews and did see the TuffWrap. Lots of good info. In the end I just ordered a ToughSkin. Bulky, but I had a previous model on an iPod and as I consider the iPhone too big for pocket use anyway (okay, it's my first smartphone I'm used to much smaller ones - maybe I'll adjust), I didn't mind adding a little more bulk. I will say if I had unlimited funds I think I'd be eyeing these.
that looks fucking retarded.
CRG also makes motorcycle accessories. Note the brake and clutch levers in the pictures. I have mirrors from CRG on my Guzzi and have seen the levers close up. CRG products are all well built. That doesn't mean that his thing isn't retarded, but it's probably a nice, well built retarded thing.
Well, I think the most retarded aspect would be many of the options have a colored screen cover. Why would you want to make the iPhones screen all red/purple/yellow? And then add a customized etching on top of it? Make those videos pop! :o
How is this usable?
But I still would like a 'naked' version.
EDIT: Okay, I'm an idiot. These are evidently (in at least some instances) flip/lids.
my first gen iPod is nude, and it's been fine since I bought it in jan. I've even dropped it quite a few times. my only complaint is I would like the screen to stay cleaner, but a quick wipe with a damp paper towel always does the trick.
Is this phone only or for the Touch too?
Answered my own question: yes, this update applies to the Touch as well. I'm installing it now.
Edited by n_maher
I know this was also discussed earlier, but since there's been some time since, anyone discover a reasonably inexpensive line-out adapter that works with the iPhone?
I had one built for me for $30, seemed reasonable. I'll let you know how it works when it shows up.
my 3g's port is an absolute pain in the ass. None of my charging plugs fit in it well. I settle for "cocked at a 20 degree angle held in place by my armrest charging 80% of the time."
I imagine the number of successful LODs is low on that bitch's abomination of a port.
The Sik Din works with my Touch, but doesn't with my iPhone unfortunately (audio wise).
As for current cables working on all models, I thought the cables were backwards compatible (not past cables not forward).
The iphone wants there to be something "authorizing" it to work, basically.
Okay, so maybe the resistor is "cheating" by sending it this signal from one of the power lines? Maybe it's just a single DC signal...well, it has to be something simple like that, if the AV cables work with it, which apple says it does.
Interesting, if uncorroborated, article about the hardware differences between the latest iPhone and iPod Touch. Apparently the Touch processor runs significantly faster than the iPhone.
has to be because of battery life, and if needed, i'm sure a firmware update is all that's necessary to give it a bump
Register a new account
Sign in
