  • Replies 135
Kevin's review of the B52 from the pictures ray has posted.
THE GOOD
The aestetics of this unit are very nice. Still way to many
ray samuels logo's and the logo's are way to big. But i happen
to like the looks of the thing. KG's rating---- A-
The quality of assembly, the quality of the parts, the quality
of the layout. Outstanding. A particular company north of the
border should look at how things are supposed to be done.
KG's rating---- A
At least the box is finally big enough so the electrolytics
won't burn up due to the heat. Still a few more holes in the
main board would definitely help.
THE BAD
Circuitry description.
Differential amplifier on the input. Turns unbalanced signals into balanced
or amplifies balanced signals. Output capacitively coupled to the 4 channel
dact step attenuator. Output of the attenuator goes two places, one
is the cathode follower preamp output stage, and the other is the balanced
srpp headphone amplifier stage. KG's rating ---- C-
Yes in fact as far as a headphone amp is concerned its 2 raptors in one box.
As a preamp it has a cathode follower output stage, so it actually really behaves
like as a preamp. Output impedance of about 2k is far better than the 100k
impedance of the stealth. I feel sorry for all those stuck with stealth's which
are now completely worthless.
Yes the headphone stage is TWO SRPP stages in series with TWO output
capacitors in series with the headphone. Double the output impedance.
Double the slush bucket bass into low impedance headphones.
THE UGLY
What is this thing. A preamp?? If so where is the remote control.
A Headphone amp?? Where is the low output impedance.
Instead of doing one thing right, it does two things wrong.
First thing if you really are going to use it as a preamp, chuck the 2 x 12au7
preamp output tubes and replace with 6n1p (after dealing with the filament
voltage issue).
But really with the same number of tubes and deleting the headphone output
it would be easy to design a new board that fits into the same chassis and
turns the thing into a conrad johnson clone. Plenty of room now for composite
triodes.
FOR A FEW PENNIES MORE ray could have actually added 2 wires into the power
supply cable and avoided contaminating the high voltage ground with the grunge
produced by the ultra cheapo fillament switchers.
The B52 really is the best thing by far that ray has ever done.
Stereophile should eat the thing up.
PS. I would appreciate if we keep that price here, as it was a special deal Peter gave me due to the custom nature of the project and my patience. It will likely be quite a bit more expensive if it ever goes to production.
No problem
