justin Posted April 3, 2023 Report Posted April 3, 2023 (edited) Colors Sovietized for effect * this should be in DIY forum Edited April 3, 2023 by justin 1
jose Posted April 3, 2023 Report Posted April 3, 2023 I remember reading about the old amps (MIGs) Kevin designed... especially one that was totally overkill but I don't remember their names.
jose Posted April 3, 2023 Report Posted April 3, 2023 @justin bad boy.... I've been looking for the schematic and the sand for an hour 😁 I couldn't find the schematic (KGDT only) but I find it: Kevin sayd: schematics for mig here. http://gilmore.chem.northwestern.edu/kgdt1.gif http://gilmore.chem.northwestern.edu/kgdt2.gif mig amp can be built balanced or unbalanced, uses grounded grid 6c33 output tube and solid state current source. (4 tubes balanced) mig2 amp can be built balanced or unbalanced uses grounded grid 6c33 output tube with a 6c33 as the current source. (8 tubes balanced)
justin Posted April 3, 2023 Author Report Posted April 3, 2023 (edited) 14 minutes ago, jose said: @justin bad boy.... I've been looking for the schematic and the sand for an hour 😁 I couldn't find the schematic (KGDT only) but I find it: Kevin sayd: schematics for mig here. http://gilmore.chem.northwestern.edu/kgdt1.gif http://gilmore.chem.northwestern.edu/kgdt2.gif mig amp can be built balanced or unbalanced, uses grounded grid 6c33 output tube and solid state current source. (4 tubes balanced) mig2 amp can be built balanced or unbalanced uses grounded grid 6c33 output tube with a 6c33 as the current source. (8 tubes balanced) a couple mistakes that I know of in the output stage: the pot is 100 to 1K the CCS transistors must be paralleled as 30W from a single TO-220 is a bad idea Edited April 3, 2023 by justin 1
nopants Posted April 4, 2023 Report Posted April 4, 2023 I remember looking at this years ago and wanting to build it, then I read some comment about how the 6c33c's have short lifespan? ...am I reading that correctly, 7A filaments?
spritzer Posted April 4, 2023 Report Posted April 4, 2023 Yup, they are very hungry tubes. Given what these are designed for, tube life should be just fine if not run on the extreme edge.
jose Posted April 4, 2023 Report Posted April 4, 2023 Kevin gave me a design with 6C33 many years ago (arround 2017). I use it constantly and in fact, it's my favorite amp. I have changed the preamp tube many times out of curiosity but never the 6C33... and that stuff already accumulates enough hours of use. 3
jose Posted April 5, 2023 Report Posted April 5, 2023 Please, could you suggest me a substitute for the 2SJ352?
justin Posted April 6, 2023 Author Report Posted April 6, 2023 I can send you some or try this? http://www.exicon.info/PDFs/ecx10p20.pdf
justin Posted April 9, 2023 Author Report Posted April 9, 2023 (edited) Here is 1 channel of a blue hawaii running on +/-100v instead of +/-400v, with a single 6as7 dual triode for balanced output instead of a pair of EL34. The tube current sources have been increased from 20mA to 75mA, resulting in a grid voltage of about -30 or similar to the original design Feedback resistors reduced to drop gain from 500-1000x to about 20x into a high impedance load i tested 1khz/50Vpp out at .008% thd in order to meet "today's standard" of 15W into 50 ohms balanced, I'm estimating 16x 6AS7G tubes per amp?? Sennheisers would work nicely with a baby blue Hawaii but IDK of any protection circuit that could be trusted to run no transformer or capacitor coupling into a dynamic or planar headphone!! That's why I think this may be a better project for the purpose of phase splitting/inversion, voltage gain, and buffer driver. For example, Kevin's 'tube input unbal/bal' board with the 6922 is basically the first 2 stages of all of the SS/Hybrid e-stat designs at lower voltage but a 6922 itself can't do the job completely if the job is to get to a low distortion 100Vpp balanced output to feed Uber-buffers to get the 15W into 50-ohms but you could use this baby BH type design, such as this with a single 6AS7 per channel or maybe 2x with the sections paralleled for more power, if wanting to have the ability to drive "Hi-Z" headphones directly with a very very good protection circuit, or maybe more realistically, a large film cap Edited April 9, 2023 by justin 9
