yuujin Posted January 9, 2008 Report Posted January 9, 2008 I did a front panel and i want to order a case with it. I opened the order program and selected the Housing Profile 1. It only allows me to define the length. Does that mean FPE will follow the width and height of my front panel? Is that the true price of the casing? Anyone tell me how to get the case? I'm exploring my options. I have lots of solid wood and i was thinking of casing my b22 with it but im worried about the heat dissipation. I've been putting the casework off for a long time and i want to finish it before the bijou comes.
yuujin Posted January 9, 2008 Author Report Posted January 9, 2008 nice. but i dont understand. Im looking at the order program. and it states $6.14 for housing profile 1. is that the full price? or do i have to order something else?
yuujin Posted January 9, 2008 Author Report Posted January 9, 2008 Im not sure if im right. But if i choose housing profile 1, which has only 4 L brackets. I have to do all the sides manually?
luvdunhill Posted January 9, 2008 Report Posted January 9, 2008 yuujin: after choosing the housing profile, you have to create the top, bottom, front and rear panels. If you're doing one of the larger profiles, you'll have to create 2 sides as well. If needed, you'll need to add holes for the L brackets. Once you get all this ready, you add the 4 panels, the side extrusion (you specify the length), the brackets, and screw kits to your FPE order using the order program.
