Urs Posted February 17, 2023 Report Posted February 17, 2023 Dear all, I’m currently considering to up-dating my STAX-compatible HeadAmp with an extra-option of a variable Polarization Voltage . Reportedly, the SR-007 Mk2 may benefit from such a higher voltage Who has experience with such a feature ? Thanks & Regards Urs
jamesmking Posted February 18, 2023 Report Posted February 18, 2023 20 hours ago, Urs said: Dear all, I’m currently considering to up-dating my STAX-compatible HeadAmp with an extra-option of a variable Polarization Voltage . Reportedly, the SR-007 Mk2 may benefit from such a higher voltage Who has experience with such a feature ? Thanks & Regards Urs if you make the bias voltage too high there will be a spark from the diaphragm to one of the audio grids. This will burn holes in the diaphragm and result in a very costly strip down and repair not to mention the possibility of damaging the Stax amp. Stax choose 580V bias for a reason it works and is reliable.
Urs Posted February 18, 2023 Author Report Posted February 18, 2023 Thanks a lot to both of you ! Case closed ! Best regards Urs Marti
spritzer Posted February 18, 2023 Report Posted February 18, 2023 Anybody claiming that Stax bias voltage needs to increased, immediately file that with "doesn't know what the fuck they are talking about". 4
