justin Posted March 10, 2023 Report Posted March 10, 2023 15 hours ago, AudioGD said: What do you think of Grand Cayman? it was great! 1 4
AudioGD Posted March 10, 2023 Report Posted March 10, 2023 11 hours ago, spritzer said: I only spent a few minutes with it using the new DCA and Shangri-la SR with an unfamiliar source so I can't really comment on it. No issues I could hear but I'd need to spend some more time with it. It's an impressive beast though. I forgot to mention I also tried the Warwick Audio Bravura... what a piece of shit that is. Now the amp was broken so no high gain mode available so I couldn't push the volume far enough. Still it is the blandest sound imaginable, it does nothing well and you can clearly hear the DSP doing its best to try and fix the sound of the single ended transducers. I suspect this will be far worse when the volume is pushed to normal levels. I actually have a couple of the Sonoma M1 headphones (dirt cheap now) and was planning on designing an amp for them (the Bravura uses the same amp) but I might not bother. They clearly can't work with a direct signal so my plan is to just reuse the housings and design proper electrostatic drivers that fit in there. What do you think of GC versus T2?
Voltron Posted March 11, 2023 Author Report Posted March 11, 2023 Didn't you get your answer already? 2
Emooze Posted March 11, 2023 Report Posted March 11, 2023 The only way to answer this question is probably to listen to both. I recommend buying both. 2
AudioGD Posted March 11, 2023 Report Posted March 11, 2023 20 minutes ago, Voltron said: Didn't you get your answer already? I was asking my engineer idol Spitzer:)
Voltron Posted March 11, 2023 Author Report Posted March 11, 2023 If you were really listening, then you wouldn't have anything to do with AudioGD, let alone name yourself after them. 1
skullguise Posted March 11, 2023 Report Posted March 11, 2023 I actually don't mind AudioGD stuff, have a couple of their cheaper items in the past. But every time I see their name I can't help but picture this in my head 1
Voltron Posted March 11, 2023 Author Report Posted March 11, 2023 I don't really know or care about AudioGD but back in the day there were many douchey fans so it still has that connotation in my mind.
