Karhu Posted November 24, 2007 Report Posted November 24, 2007 Hello, this is my first post here. I have Stax SR-303/SRM-313 combo. It works well with my vinyl player but with cd it is cold and boring. Cd (Audio aero prima) is fine with my speakersystem, so I?m not going to change it. I got an idea of DIY tube amp with SR-303. Having read many threads here and the other, now malfunctioning forum, I have found this Gilmores schema: http://headwize.com/projects/gilmore_prj.htm Is this a good schema? What else would you recommend? I won?t make this myself, have to make it by an experienced amp maker, so it can be a relatively complicated amp like that of Gilmores. Quote
spritzer Posted November 24, 2007 Report Posted November 24, 2007 That is a good design and is the same as Woo Audio uses in their Woo GES amp. There are a lot of Stax amp designs out there but most of them are in Japanese. The Tubecad design is also pretty good and simple and a little more interesting is the other Gilmore tube design. Quote
Karhu Posted November 24, 2007 Author Report Posted November 24, 2007 That is a good design and is the same as Woo Audio uses in their Woo GES amp. There are a lot of Stax amp designs out there but most of them are in Japanese. The Tubecad design is also pretty good and simple and a little more interesting is the other Gilmore tube design. Can you tell me where I can found this other Gilmore tube design, please. Quote
spritzer Posted November 24, 2007 Report Posted November 24, 2007 Can you tell me where I can found this other Gilmore tube design, please. Here Just use any PSU you want but the Blue Hawaii unit would work. I'm slowly gathering parts for this one and I'll build it one day. Quote
Karhu Posted November 24, 2007 Author Report Posted November 24, 2007 Here Just use any PSU you want but the Blue Hawaii unit would work. I'm slowly gathering parts for this one and I'll build it one day. Thank you! And Blue Hawaii PSU can be found...? Quote
Pars Posted November 24, 2007 Report Posted November 24, 2007 http://headwize.com/projects/showfile.php?file=gilmore4_prj.htm Quote
n_maher Posted November 24, 2007 Report Posted November 24, 2007 Just one more piece of advice, chose your builder carefully. There is a good bit of truth to the "you get what you pay for" axiom. Quote
Karhu Posted November 24, 2007 Author Report Posted November 24, 2007 Yes, if i had money for Blue Hawaii and O2 I wouldnt ask these questions, but my purpose is not to make this cheapest possibly way either. Quote
spritzer Posted November 24, 2007 Report Posted November 24, 2007 The Head3 design is pretty simple to build if you opt for NE-2's instead of the 0A2's. A lot less space is needed and the 0A2's plus sockets are more expensive. Quote
kevin gilmore Posted November 24, 2007 Report Posted November 24, 2007 The head3 design is all solid state with the apex chips. The NE-2's are actually better because they are significantly stiffer. But then the rest of the thing is highly boring, as only 8 tubes are visible, and no pretty glow lamps. Quote
spritzer Posted November 24, 2007 Report Posted November 24, 2007 The head3 design is all solid state with the apex chips. Ohhh, I called it after the page name but DC tube driver will do just fine. The NE-2's are actually better because they are significantly stiffer. But then the rest of the thing is highly boring, as only 8 tubes are visible, and no pretty glow lamps. I'm going with 0A2's and the sockets for them should be here soon. I like pretty lights... Then I'm only short the 6H30 tubes... Quote
Karhu Posted November 24, 2007 Author Report Posted November 24, 2007 Yes, if i had money for Blue Hawaii and O2 I wouldnt ask these questions, but my purpose is not to make this cheapest possibly way either. I have expressed myself badly. I meant that I cannot afford Blue Hawaii amp or OmegaII headphones. 0a2 tubes are not too expensive. Quote
spritzer Posted November 24, 2007 Report Posted November 24, 2007 I have expressed myself badly. I meant that I cannot afford Blue Hawaii amp or OmegaII headphones. 0a2 tubes are not too expensive. No they aren't. I bought a large lot of them for about 30$. Quote
luvdunhill Posted November 26, 2007 Report Posted November 26, 2007 I have expressed myself badly. I meant that I cannot afford Blue Hawaii amp or OmegaII headphones. 0a2 tubes are not too expensive. Karhu: There are some "simpler" (i.e. cheaper) projects here: http://high-amp.de/html/frame.html Quote
Karhu Posted November 26, 2007 Author Report Posted November 26, 2007 Karhu: There are some "simpler" (i.e. cheaper) projects here: http://high-amp.de/html/frame.html Interesting link, new to me. Thank you. Quote
Tachikoma Posted December 2, 2007 Report Posted December 2, 2007 The head3 design is all solid state with the apex chips. The NE-2's are actually better because they are significantly stiffer. But then the rest of the thing is highly boring, as only 8 tubes are visible, and no pretty glow lamps. Is that the only reason you recommended against the NE-2s in the old head-fi thread? *thought it'd have something to do with noise issues and whatnot* I'm still waiting for my BH PSU PCB from justin to get started with the DC tube amp, meh. Quote
