What Volume do you listen to your music at?
  1. 1. What Volume do you listen to your music at?
    • Whisper quiet - 7 to 8 o'clock
    • Normal - 8 to 9 o'clock
    • A bit loud - 9 to 10 o'clock
    • Loud - 10-11 o'clock
    • Earbleed - 12 o'clock +
    • I listen so loud that up to a half hour after finishing a session, I can go to the bathroom and pee decaying transients.
    • It goes to 11, so I listen at 11
i have the volum with my E5s and iPod at about 75%. i guess that's pretty fucking loud, but it's not as loud as i used to listen, and my tinnitus is fading.
wait...don't you gain your files?
I listen at fairly low levels most of the time, which is what got me into the better gear in the first place. I could finally hear everything without having to turn it up. Sometimes, though.... :kitty:
Some iPods are louder than others. I used to listen to an old 4G iPod with my E5s at 85-90% which looking back was completely crazy. I realised that would be a quick path to hearing loss so I went cold turkey for a while and then tried to re-accustom myself to lower volumes. With this I managed to get used to having it at around 40-50% volume. I've since switched to the 6G iPod but that needs to be at about 75% volume to reach the same level as the 4G at 50%. Today though I'm quicker to drop the volume down if I think it's a bit loud.
I just remembered; I usually did 70% to 75% on the iPod with my K701.
I really need to check out how loud I listen to music with a SPL meter. :)
I turn the phones up until the neighbors start complaining, anything else just isn't sufficient.
Coincidentally this is only half as loud as philodox listens.
hehe, that was great :)
I had a chance to check the levels for my listening when Nate was still running his Wheatfield / K340 combo with his SPL meter. I have some damage to my left ear from a combination of riding around in Jeeps and working front-of-stage security while (stupidly) not using hearing protection. So it was nice to see that I still have good enough hearing that I'm able to play it somewhat safe in the low to mid 70 dB range. And that was on par with the levels I usually have my Millett / HF-1 rig at, though for long periods like when working at home I try to keep it lower, and will occasionally nudget it higher when something like Opeth's "Demon of the Fall" comes on!
how do I get an SPL measurement with my Stat setup?
Neil
It's a bit harder doe to their dipole nature but if non accurate measurements are find just measure between the drivers. If you want to be hardcore buy a Head acoustic headphone measurement dummy head... ;D
On my dynamic amps using a source with good gain, I usually listen between 9-11 o'clock. If I plug in my Iriver or iMod the volume needs to be increased.
On electrostat amps that I have or have had, like the KGSS, 007t, and GES, HEV-90, I find that I need to go to 1 o'clock to achieve the same volume.
