n_maher Posted November 14, 2007 Report Posted November 14, 2007 (upgrading my vinyl rig) Well then here's your new phono stage. Quote
Nanoha Posted November 14, 2007 Report Posted November 14, 2007 Well then here's your new phono stage. Dew eet! Quote
aerius Posted November 14, 2007 Report Posted November 14, 2007 It's an excellent phono amp, you should definitely get one. Or maybe you can get their pre-amp... Quote
philodox Posted November 14, 2007 Report Posted November 14, 2007 Not a big fan of how that one looks. \ Quote
Dusty Chalk Posted November 14, 2007 Report Posted November 14, 2007 AudioValve RKV with Impedanzer is intended to drive speakers...but it's not SET. Quote
deepak Posted November 14, 2007 Author Report Posted November 14, 2007 aerius any estimate on how much the Wavelength Bugle would cost to build? Quote
aerius Posted November 14, 2007 Report Posted November 14, 2007 aerius any estimate on how much the Wavelength Bugle would cost to build? Looks to be in the ballpark of $1-1.5k depending on the parts used and how fancy you get with the case. I could be a bit on the low side since I haven't priced out capacitors lately. Quote
aerius Posted November 19, 2007 Report Posted November 19, 2007 And now for something completely different. A push-pull design using directly heated pentodes. Puts out around 4 watts per channel. Quote
spritzer Posted November 19, 2007 Report Posted November 19, 2007 This could be turned into a Stax amp as well. Could be pretty nice indeed Quote
deepak Posted November 20, 2007 Author Report Posted November 20, 2007 I'm going to use the Beetah twenty twos speaker outs with the Duos in the in term. Thanks for all the feedback guys, but I realized an in between amp would drive me crazy and it will be all that much sweeter when I get those 300B amps. And I might get a chance to hear the B22 with some Duos, depending on when it's finished. e: I still need a preamp (preferrably with remote, laziness ftw) Quote
slwiser Posted November 20, 2007 Report Posted November 20, 2007 Here is another temp solution: http://www.decware.com/newsite/mainmenu.htm?/newsite/dm944.htm&intro for 675$ or http://www.decware.com/newsite/images/tabooblacksmall.jpg for 995$ To be found at www.decware.com . Check out the HDT speakers while you are at it. These have been very well reviewed over in the Asylum and AudioKarma. Quote
deepak Posted November 20, 2007 Author Report Posted November 20, 2007 I do appreciate it slwiser, but nothing beats paying nothing to use my B22 Quote
Nanoha Posted November 20, 2007 Report Posted November 20, 2007 What is your pre going to be? Going integrated? Using your b22 as a pre? Quote
deepak Posted November 20, 2007 Author Report Posted November 20, 2007 What is your pre going to be? Going integrated? Using your b22 as a pre? The B22 will be an integrated amp (with nice headphone amp ) When I get the blocks I'd like a pre with a remote control. Quote
Nanoha Posted November 20, 2007 Report Posted November 20, 2007 When I get the blocks I'd like a pre with a remote control. Ah ha. I see. Quote
deepak Posted November 20, 2007 Author Report Posted November 20, 2007 Ah ha. I see. The last thing I'm doing after busting my ass all day is getting up and walking 10 feet to change the volume Quote
n_maher Posted November 20, 2007 Report Posted November 20, 2007 I'm sure the beta could be reconfigured to use both remote volume and source control. That'd be the route I'd go before adding another preamp to the chain. Quote
grawk Posted November 20, 2007 Report Posted November 20, 2007 The last thing I'm doing after busting my ass all day is getting up and walking 10 feet to change the volume There's always that balanced remote 99 step attenuator that sft used in the dynamights. Quote
JBLoudG20 Posted November 20, 2007 Report Posted November 20, 2007 I'm sure the beta could be reconfigured to use both remote volume and source control. That'd be the route I'd go before adding another preamp to the chain. I can hook that up jpak, if you so choose. Quote
n_maher Posted November 20, 2007 Report Posted November 20, 2007 There's always that balanced remote 99 step attenuator that sft used in the dynamights. Yet another link that I will have lost if Head-fi doesn't come back. Quote
JBLoudG20 Posted November 20, 2007 Report Posted November 20, 2007 Jpak, here is a decent option: http://eshop.diyclub.biz/product_info.php?cPath=85&products_id=195 Quote
n_maher Posted November 20, 2007 Report Posted November 20, 2007 Jpak, here is a decent option: http://eshop.diyclub.biz/product_info.php?cPath=85&products_id=195 Doesn't it need to be 4-channel for balanced operation? Quote
grawk Posted November 20, 2007 Report Posted November 20, 2007 http://eshop.diyclub.biz/index.php?cPath=85_186 http://eshop.diyclub.biz/product_info.php?cPath=85_186&products_id=217 Quote
