Diamond drag engraving is surprisingly fun and easy.
I decided to buy a spring loaded diamond drag engraver and do some experimentation on feeds, cutting depth, stepover etc.
I ended up. 90 degree drag bit. tip flat estimated at 0.128mm, 0.1mm step over, fill crosshatch at 0 degree, 700mm/min feed speed.
Far better results than using a V bit, much less sensitive to the material not being totally flat and far far faster.
  • Like 3
Register a new account
Sign in
