qqiao Posted June 3, 2022 Report Share Posted June 3, 2022 Hi stax experts, I measured my t1w bias voltage, the pro bias port is 420v and normal bias is about 150v, is this normal or something needs to be replaced? Thank you. Quote Link to comment Share on other sites More sharing options...
jamesmking Posted June 4, 2022 Report Share Posted June 4, 2022 (edited) 9 hours ago, qqiao said: Hi stax experts, I measured my t1w bias voltage, the pro bias port is 420v and normal bias is about 150v, is this normal or something needs to be replaced? Thank you. if you are using a multimeter with a 10Mohm input impedance then you will not measure the actual voltage. The stax bias output is very high impendence i.e. provides very very little current and so even the current draw of a 10Mohm multimeter will load down the bias and you will measure lower than expected. Either you need a meter with a Gohm or higher input impedance at 1000V or you need to measure before the current limiting system on the bias output. For example the golden reference HV power supply bias circuit has a 4.7Mohm current limit resistor just before the output so you need to measure before that limiting resistor and of course be careful because if you multimeter can't handle 580V or you touch the probes etc you will get a non-current limited 580V DC shock which is not going to be good for you. incidentally I get about 378V DC at the socket on my diy T2 (pro bias only) into a 10Mohm meter BUT this value is going to be very dependant upon the value of the current limit resistor in the bias circuit. So if you amps current limit resistor has a lower value then 420V is not necessarily unrealistic. Edited June 4, 2022 by jamesmking 2 Quote Link to comment Share on other sites More sharing options...
qqiao Posted June 4, 2022 Author Report Share Posted June 4, 2022 Hi Jamesmking, Thank you very much for the details. The t1w has an adjust resistor for one pro bias port, so it can give 3 different bias voltage, a very versatile amplifier. Quote Link to comment Share on other sites More sharing options...
qqiao Posted June 4, 2022 Author Report Share Posted June 4, 2022 https://i.imgur.com/Dz9hxo6.png I found the schematic fo 007, the bias circuit should be similar as t1, actually I don't fully understand how it can get 580v voltage, the output from the transformer only provides 270v, it looks like a half wave rectifier circuit. Quote Link to comment Share on other sites More sharing options...
spritzer Posted June 4, 2022 Report Share Posted June 4, 2022 It's a voltage divider feeding a voltage doubler Quote Link to comment Share on other sites More sharing options...
qqiao Posted June 4, 2022 Author Report Share Posted June 4, 2022 understand, thanks very much for the explanation. Quote Link to comment Share on other sites More sharing options...
Kung Posted June 14, 2022 Report Share Posted June 14, 2022 (edited) On 6/5/2022 at 1:44 AM, qqiao said: https://i.imgur.com/Dz9hxo6.png I found the schematic fo 007, the bias circuit should be similar as t1, actually I don't fully understand how it can get 580v voltage, the output from the transformer only provides 270v, it looks like a half wave rectifier circuit. According to your 007t schematic, if the transformer outputs 270VAC, the voltage doubler will give you about 360+VDC bias. If the transformer outputs 435VAC, you will have a standard 580VDC pro bias. because there is no voltage regulator, the turn ratio of transformer will be conservative for wider range of voltage fluctuation. Edited August 24, 2023 by Kung Quote Link to comment Share on other sites More sharing options...
