Been liking the A250 a lot lately. Don't know what the hell is wrong with me. The brightness doesn't bother me quite as much. Very nice airy and open sound, clear, great soundstage, good bass, really crisp/sharp attack with extended decay. very dynamic. Maybe this is my mind trying to tell me to get the ESP950? If it is anything like the A250 but minus the colored mids and excessive treble energy I willl probably like it a whole lot.
Don't know how it ranks but it's not going to threaten the O2 any day soon.
Yeah, it's usually a peak around 7-8kHz where the bulk of the "s" sound is. Peaks around that area generally set off sibilance though it can sound different depending on where the peak is.
The A250 has some sibilance, but mostly it's a general treble emphasis.
Yes, in general, the lower in the 6-9 kHz range the peak is, the worse (and grating) the sibilance.
Btw, I used to own the A250 and it was a sibilant mess, but I thought that it was mostly poor handling from my amp. Another can which changed completely its character with different amps was the Sony CD3000. I tried it with a Mini3, iBasso T4, CKKIII and even unamped iAudio 7. The highs were the most pleasent when using the Mini3 or the dap, the CKKIII used to make them a bit sharper. The T4, surprisingly (since it's usually opaque), turned the CD3k into a hell of sibilance.
Chocolate donut mkII
AKG K340 (rewired and on its way to becoming fully modded)
HD650 ties with SR-225 (HD650 gives a better presentation but is dull at the volumes I listen at, SR-225 is fun but uncomfortable and has too forward a bass presentation for me).
Proline 750, its good for testing things and folds away small, not used for pleasurable listening.
HD800
O2 Mk1 (just waiting for a better amp)
HP1/HP2 (tied, polarity switches don't better/worsen the sound, so tied with button version)
ESW10JPN (simply because of value/performance ratio and bonus points for portability)
HF2
RS1/HD600 (tied for me, depends on mood)
HF1/MS2i (harldy use these, so don't remember, that will change as they will be put into rotation)
GS1000
V-moda vibes (use these during exercise)
Which T50 do you have? I assume the current gen T50RP, or worse yet, the T50RP with non-sealing pads.
Is the current T-50RP and the pads have wrinkles.
So a bassless stock T50RP. Yeah, I'd rank them last, too. Especially if I liked a big, healthy amount of bass like it seems you do from all your other headphones.
I'd try to rerank my headphones but a lot of them are still not quite functional. If only someone would give me back my shitty soldering station.:palm:
updated
Tier 1: Headphile AKG K340, ATH W5000, ATH AD2000, ATH W11JPN
Tier 2: ATH A900ti, modded YH100, Balanced HD650 (maybe these just needed tubes), K501,
Tier 3: K240DF, DT531, K241(K240LP),
Tier 4: W100 w/ W5000 drivers, HD25-1, AKG K271, AKG K141, DT880 '05 Edition, MD5000,
Tier 5: K240MP, K240 Anniversary, Shure SCL2, AKG K81 DJ
There's a good chance the W5000 and AD2000 would be rated better than the K340 if they were amped with the Zana Deux
Tier 1: these are a joy to listen to
Tier 2: slight shortcomings but very nice
Tier 3: not quite sure about these, a little too kinky for my taste
Tier 4: huh?
Tier 5: giveaways
Tiers 4 & 5 really shouldn't be rated, they failed at a lot of things
ooh you received your modded Yh-100..Nice
I received mine too. :P
another mistake: (I messed up the tier description)
Tier 3: could live with this if I hadn't tasted the forbidden fruit
Tier 4: not quite sure about these, a little too kinky for my taste
Tier 5: giveaways
  • 3 months later...
Including the ones I had previously:
MS Pro Ulti
DT880'600 (closed back)
CD3K
PK1
K271
MS1K
DT880'2003
DT880'2005
MS2i
ANC7
DT531
A900
DT770'2003
DT990 old
KSC75, PP, EP630 & alike
HD595
that Vivanco ...thing
Past and present (some headphones might be off by one tier, depending on my mood):
Tier 1
AKG K1000
Tier 2
Stax Lambda, Stax Lambda Pro, Stax Lambda Sig, SR-X mk3 -> now Pro, Jecklin PS2
Tier 3
SR-5NB, ESP10, Superex PEP-74, Beyerdynamic ET1000, AKG K340
Tier 4
Fostex T20v2, Fostex T40v1, Concept CE-H, Audio Technica ATH-702 SFI, AKG K501
Tier 5
AL im716
Tier 6
Fostex T50RP, Ety ER6i
Tier 7
AKG MP and LP Sextetts
Tier 8
KSC75
A lot of these rankings could and will change because I haven't gotten around to modding a lot of these headphones yet. Will get around to the ET1000 tonight, at the very least.
