if anyone hasn't use FPE before, let me know as I have a referral discount code I can share with you. It gets 20%.
The discount might be worthwhile as I have a multi-panel order coming up. Is it only good on a single panel? I'm not exactly a new customer but it's been a while and I could probably *appear* to be one...
it's an entire order :) The code is 2Q0WLWUF
Wow! I'm impressed. Do you work for Nelson Pass?
I recently read a tip from Ed Simon I plan to try out... cut thin strips of antistatic foam from sheets and spray glue them in rows to notebook divider tab pages. You can put a dozen or so rows on a sheet, each row can hold dozens of TO92 devices, and there's room in between to write whatever on the divider sheet. The devices slip into the foam parallel to the page. Then you can supposedly put 1000+ parts in a single 3 ring binder with the applicable P/N's and measurements in pencil.
