grawk Posted October 7, 2007 Author Report Posted October 7, 2007 Let me know if you're having trouble Dan, my cable supplies order came in Friday so I've got enough stuff to make a quickie that would help you raise some more funds. The most important questions is: how's your amp doing? It sounds great. There may be a relay issue, it's taking forever for the muting circuit to shut off on powerup, but I didn't spend a lot of time at the meet worrying about that. I'll check it out when I get the amp set back up in a few days. Quote
n_maher Posted October 7, 2007 Report Posted October 7, 2007 It sounds great. There may be a relay issue, it's taking forever for the muting circuit to shut off on powerup, but I didn't spend a lot of time at the meet worrying about that. I'll check it out when I get the amp set back up in a few days. IIRC the delay is variable based on what headphones you have plugged in (their impedance plays a role) so you may find that it's longer or shorter depending on what you're using. As long as it's eventually closing and staying closed it's probably working just fine. Quote
