  • 1 year later...
  • 2 months later...
Well, I wasted more time on this. Here is what I know.
if I put a level across the top of the bracket, the top right I can slide two washers under the straight edge and the bottom right three washers. So I thought to myself, obviously I need to space the bracket out from the wall accordingly. Well, same exact problem. When I snap the TV in, the bottom right left is about 3/8” out from the wall (other corners are flush with the wall) and there is a decided bend in the panel
The shadows from from the overhead lights here might offer a clue:
if not here are some attempts to show the problem (this is with the washers spacers installed behind the mounting bracket)
Edited by luvdunhill
  • 2 years later...
