morphsci Posted June 19, 2019 Report Posted June 19, 2019 I have a Marantz AV7005 that has been sitting in its box in an air conditioned storage unit since we moved to Florida. It is yours for the shipping cost if you want it. 3 Quote
grawk Posted June 19, 2019 Report Posted June 19, 2019 That’s total overkill but I’ll definitely take it, it’ll get the job done Quote
morphsci Posted June 19, 2019 Report Posted June 19, 2019 I will get it out of storage tomorrow and get back to you. 3 1 Quote
luvdunhill Posted September 10, 2020 Report Posted September 10, 2020 I am really excited about the Marantz NR1711! https://www.us.marantz.com/en-us/shop/avreceivers/nr1711 Pretty featured packed. Will be my third slim-line, following various updates they have made. 1 Quote
swt61 Posted September 10, 2020 Report Posted September 10, 2020 They pack a lot in that small chassis! Quote
luvdunhill Posted September 10, 2020 Report Posted September 10, 2020 I am considering what would be a 5.2.2 Dolby Atmos System which would leverage some existing ambient speakers for the “overhead mids” with a switch in the wall to toggle them. Here is the guide: https://www.dolby.com/siteassets/technologies/dolby-atmos/atmos-installation-guidelines-121318_r3.1.pdf Quote
swt61 Posted September 10, 2020 Report Posted September 10, 2020 I'd have to hear it to get the effect, but it sounds interesting. Both subs are the same? I've often thought about a quick 10" sub, supported by a deeper 15". 1 Quote
skullguise Posted September 10, 2020 Report Posted September 10, 2020 23 minutes ago, swt61 said: I've often thought about a quick 10" sub, supported by a deeper 15". There's a guy in here named Steve that should make a joke about this..... 2 Quote
swt61 Posted September 10, 2020 Report Posted September 10, 2020 If anybody is seriously considering 15", I've over inflated expectations. 1 Quote
guzziguy Posted September 10, 2020 Report Posted September 10, 2020 Are we talking length or circumference? Quote
swt61 Posted September 10, 2020 Report Posted September 10, 2020 Could you imagine 15" in circumference? I sometimes have a hard time talking some into "it", at close to 1/2 of that. 😳 Anywho, back to home theater. 1 Quote
Fitz Posted September 11, 2020 Report Posted September 11, 2020 22 hours ago, swt61 said: They pack a lot in that small chassis! I'm sure you're quite familiar with packing a lot into a small chassis. Quote
skullguise Posted September 11, 2020 Report Posted September 11, 2020 I looked at the specs on the Marantz slim model, very nice but only 50 wpc.....would need fairly efficient speakers methinks, a smaller room, or maybe use a separate multi-channel amp... Quote
Grahame Posted September 11, 2020 Report Posted September 11, 2020 Or use active speakers from the pre-outs? 2 Quote
luvdunhill Posted November 26, 2020 Report Posted November 26, 2020 Does anyone have the LG GX model on the included slim wall mount? I am not sure if my wall isn’t flat or the panel isn’t flat ... but something ain’t flat. 1 Quote
n_maher Posted November 27, 2020 Report Posted November 27, 2020 How unflat? It wouldn't be all that surprising to find a wall 1/8" out of flat in say 4' or so but not more than that. Quote
luvdunhill Posted December 6, 2020 Report Posted December 6, 2020 (edited) Well, I wasted more time on this. Here is what I know. if I put a level across the top of the bracket, the top right I can slide two washers under the straight edge and the bottom right three washers. So I thought to myself, obviously I need to space the bracket out from the wall accordingly. Well, same exact problem. When I snap the TV in, the bottom right left is about 3/8” out from the wall (other corners are flush with the wall) and there is a decided bend in the panel The shadows from from the overhead lights here might offer a clue: if not here are some attempts to show the problem (this is with the washers spacers installed behind the mounting bracket) Edited December 6, 2020 by luvdunhill Quote
luvdunhill Posted November 15, 2023 Report Posted November 15, 2023 Well, this exists now: https://www.minidsp.com/products/minidsp-in-a-box/flex-ht I never thought I'd go back to HT separates ... but maybe. Thoughts? Quote
luvdunhill Posted November 15, 2023 Report Posted November 15, 2023 I suppose there is https://www.minidsp.com/products/ht-series/flex-htx Quote
