8 hours ago, naamanf said:
A little better, Iā€™ll probably live with it since itā€™s perfectly function and will remind me what not to screw up.Ā
Since you screwed this up so much, I recommend you just throw it all away and start over. Just consider this a practice run.
Also, on an unrelated subject, I am doing research on the days peoplesā€™ trash is picked up across Head-Case for a white paper I am writing. Ā Please send me your address and pick-up day for my studies.Ā
  • Haha 4
Yeah, I watch all those guys.
My issues usually arise with equipment, e.g. I have no jointer so I use a sled on the table saw, table saw sled can only accommodate about a 16ā€ board due to the tiny top on the job site so cannot joint, leading to issues. Ā
Then donā€™t get me started on trying to finish a 42x30 crate on plywood sheets on a table in the garage as it is too cold to do anything outside so I could use all the spray equipment piled on a shelf.Ā
Space and tool limitations are my biggest cryptonite as well.
If I ever win the lottery, I'll have the biggest, Best stocked shop on the West Coast!Ā
I think the Festool Vac is the best thing they make. Ā No idea about Hilti, are you talking about their construction wet/dry vacs?
I am selling the little sawstop tonight and picking up a PCS tomorrow. Ā Going to sling up some kind of ceiling harness that I can use to Mission Impossible around the garage to use the different pieces of equipment.
  • Haha 1
12 minutes ago, swt61 said:
You can set the Festool to automatic, plug your toolĀ  into it, then it'll turn on and off with the tool.
Not with battery tools šŸ˜‰
The Hilti seems nice.
Hilti seems to have the auto filter cleaner which I believe does not come with the HEPA filtered Festool.Ā
They also mention a BT remote for battery tools but I did not see if that is like the Festool or just a handheld remote.Ā
Ā
Ā
Checking out the Hilti. Seems solid and they do have a Bluetooth module in Europe that is just like the Festool, would just have to order from there or wait for it to come here. Choices, feel like I need to make the right decision when buying something that sucks.Ā
Ā
  • Haha 2
Looks decent. Ā I think I like the brakes on the Festool better than that system but the gauge for bag fill and stuff would be nice.
Going from the Sawstop Jobsite Pro which just required I pull it out of the box and put the blade on to the new PCS with 20 boxes and having to build the whole thing is quite the adventure.
  • Like 3
