Decided to try some power carving with the new Kutzall discs in the angle grinder. Definitely a bit janky due to not keeping track of the depth of cut and making it to the second layer of slab for some weird grain changes.Ā
Ā
Edited by VPI
  • Like 1
I am going to just pretend the grain change js a design feature.Ā
Ā
Starting a slat towel cabinet for the downstairs bath in Sapele to match the Sapele bathtub tray in there.Ā
I also found the source of the unknown wood I had that we discussed a few weeks ago. Ā It is Narra and the weird wood in my stop gap is Amazonique. Ā I knew it was something about the amazon.
Ā
  • Like 1
When you posted Amazonique, I assumed it would be a South American species. After seeing its from West Africa, I looked closer to see it's Amazique.
A nice looking wood no matter the name.
Narra I have heard of, but don't believe I've worked with.
First dry fit did not have any disasters so now break it down and sand everything and I believe I am going to put a coat of finish on before glue up to try to limit annoying glue scraping.Ā
  • Like 8
Put the first coat on the Spa Towel Rack and while I was waiting for it to dry I power carved another bowl to go on top of it to hold her bath bombs.Ā
  • Like 6
My personal opinion is that in something like a tool cabinet in the shop, why not go all out and be bold.
In terms of large furniture inside the house I'm more conservative.Ā
I always consider you the most conservative amongst us Steve.Ā
Ā
Also, I have stickers. Where are the Milo & Otis Woodworking and Magic Ping Pong Table stickers?
Ā
Also #2. I am already sick of the shills drooling over the stupid, tiny Festool battery powered ā€œtable sawā€.Ā
Ā
Edited by VPI
That is really neat. I'm a great fan of Sapele, but it can be a real bugger to get a good finish because of the cross grain nature of that wood. Because of that, putting it through a planer always produces tear out regardless of the direction of feed. I always end up using a scraper to get a good finish.
With that in mind - how did you get such a great finish?
I honestly have used Sapele in so many builds with so many finishes (Arm-r-seal, Odie’s, Total Boat Halcyon, Tried and True) and I have never had issues with getting a glass finish. The Halcyon is much harder to get this with as it loves to pool in crevices, but all manageable. May be the helical heads on the planer/jointer or just luck, but my only issue with Sapele is router work on the edges and getting chip out.Ā
Ā
I do sand with 0000 steel wool between coats to smooth things out and do a bit of a flood coat on the first coat for the grain you reference.Ā
The difference is absolutely helical heads vs. standard planar knives.Ā
Plus, they send the best straight grained Sapele to the USA, because that's where the best woodworkers are!
šŸ˜
  • Thanks 1
  • Haha 2
My unorthodox handtool shelf is coming together. Handfitting the figured walnut drawer front and need to come up with some access piece for the top.Ā
Ā
Ā
  • Like 2
šŸ˜
But straight grained is just not as attractive as cross grained (Krenov quirkily called such wood "rowed" - so the grain in interlocking rows). But it is a sod to finish properly, but definitely worth the effort.
But that I had a helical head knife planer/thicknesser!
I use Sapele as a substitute for mahogany. Because mahogany is CITES listed, many woodworkers buy old mahogany furniture and break it for the wood. I think that is a bad way of misusing old furniture, so I use sapele.
Looking for some guidance from the experts. I am using a french cleat to hang the cabinet, just cannot decide if I need to reinforce the cleat/add another or if the scheme I am using will be strong enough. Ā Probably will be about 40-60 pounds total.Ā
Ā
