naamanf Posted January 12, 2023 Report Posted January 12, 2023 19 minutes ago, VPI said: Everything seems to be working and already dramatically better than the shitty Jet it replaced. So quiet… IMG_3037.MOV 9.39 MB · 0 downloads So far I’ve really enjoyed my Voyager, at some point I want to put a good keyless chuck in.
swt61 Posted January 12, 2023 Author Report Posted January 12, 2023 Even Dr. Wood can make a mistake. Sorry about your larger holes Doug.
naamanf Posted January 12, 2023 Report Posted January 12, 2023 Tossed together this simple pocket hole machine. Just waiting on the router bit to show up to give it a try.
Voltron Posted January 12, 2023 Report Posted January 12, 2023 Is that the bit that you're going to use in your pocket hole? I really don't like that clamp placement, but I guess it depends on which way you face when you sit on that thing. 2
naamanf Posted January 12, 2023 Report Posted January 12, 2023 (edited) It’s making the pocket just like a Castle machine would, clamp is just there to hold the material while the pocket is cut. Offset to make the alignment mark easy to see. Operated from the side the picture was taken. Edited January 12, 2023 by naamanf
swt61 Posted January 13, 2023 Author Report Posted January 13, 2023 Cool, but why does it have a toilet paper holder?
naamanf Posted January 13, 2023 Report Posted January 13, 2023 Just now, swt61 said: Cool, but why does it have a toilet paper holder? I got a bidet and no longer need it in the bathroom.
swt61 Posted January 13, 2023 Author Report Posted January 13, 2023 Oh, that's the lever to raise the router bit. Got it. Sweet indeed! When will mine be ready? It really is a great idea!
naamanf Posted January 13, 2023 Report Posted January 13, 2023 1 minute ago, swt61 said: Oh, that's the lever to raise the router bit. Got it. Sweet indeed! When will mine be ready? It really is a great idea! I can send you a flat pack of the parts, saved the ping pong files.
swt61 Posted January 13, 2023 Author Report Posted January 13, 2023 (edited) Hell yeah, I'll buy it! Edited January 13, 2023 by swt61
Voltron Posted January 13, 2023 Report Posted January 13, 2023 2 hours ago, naamanf said: It’s making the pocket just like a Castle machine would, clamp is just there to hold the material while the pocket is cut. Offset to make the alignment mark easy to see. Operated from the side the picture was taken. Did you really not get my "joke"? 🥺 See, if that thing were a fuck machine and you sat on it facing the clamp then the clamp would crush your junk. While being penetrated. Get it? 😣 Cool idea for pocket holes tho, bro.
swt61 Posted January 13, 2023 Author Report Posted January 13, 2023 What happens in the shop stays in the shop! 1
naamanf Posted January 13, 2023 Report Posted January 13, 2023 Just now, Voltron said: Did you really not get my "joke"? 🥺 See, if that thing were a fuck machine and you sat on it facing the clamp then the clamp would crush your junk. While being penetrated. Get it? 😣 Can you make a venm diagram? It all sounds terribly and I’m considering burning my phone to hopefully forget the visual of a spiral btt attacking my taint. But at least it will be clean, thank you bidet. 3
swt61 Posted January 13, 2023 Author Report Posted January 13, 2023 Once again, proof that twinks are much tougher than your average straight male.
VPI Posted January 17, 2023 Report Posted January 17, 2023 Has anyone used either the Omniwall or Wall Control products in your shops? Thinking of going with one of those behind the drill press table instead of French cleats.
VPI Posted January 19, 2023 Report Posted January 19, 2023 For the short term at least, I threw up some French cleats and threw together a holder for the Clamp Squares and the Infinity Tools Woodworkers First Aid kit. 6
naamanf Posted January 19, 2023 Report Posted January 19, 2023 Nice! tested out my new pocket hole machine. It makes holes. 5
VPI Posted January 19, 2023 Report Posted January 19, 2023 Those are some serious holes. My Castle and Foreman both put the screws well inside the holes, yours seems to get more of the meat of the board involved. How does yours adjust for different screw lengths?
swt61 Posted January 19, 2023 Author Report Posted January 19, 2023 51 minutes ago, naamanf said: Nice! tested out my new pocket hole machine. It makes holes. That is very cool!
VPI Posted January 23, 2023 Report Posted January 23, 2023 Mocking up a MCM step stool for the guest bathroom for the cousins’ kids after building another french wall tool holder this afternoon. 6
VPI Posted January 23, 2023 Report Posted January 23, 2023 Thanks. I would have preferred to do something bigger but most everything left out in my shop develops rust so I just put the cheap stuff out.
n_maher Posted January 23, 2023 Report Posted January 23, 2023 8 hours ago, VPI said: Thanks. I would have preferred to do something bigger but most everything left out in my shop develops rust so I just put the cheap stuff out. Are you running a dehumidifier, Jeff? If not, might be worth trying to see if it helps even if it is unlikely to cure the issue. I know my shop, without the DH running, goes through huge swings of humidity. Given the heat/coldsink that most tools represent they attract condensation like crazy which is likely the cause of some of your rust problems.
