VPI Posted May 14, 2022 Report Posted May 14, 2022 Yeah, I was thinking dominos but worried the treated 4x4s would shrink down and cause issues with solid connections to hardwood. Quote
dsavitsk Posted May 14, 2022 Report Posted May 14, 2022 Wood doesn't appreciably move lengthwise, so you can minimize the effect from wood movement by constructing accordingly. Quote
VPI Posted May 14, 2022 Report Posted May 14, 2022 Yeah, my concern was the 4x4s shrinking/twisting while glued to a non-stretching hardwood in the middle. I think an inset domino job will be the best way to go…if I can remember how to do one of those. Or maybe a welded steel holder for it. Quote
dsavitsk Posted May 14, 2022 Report Posted May 14, 2022 4x4's should be pretty stable. Softwood doesn't move any more than hardwood. But if it is a concern, you can build your own stable 4x4's from 2x12's using this trick: Quote
VPI Posted May 14, 2022 Report Posted May 14, 2022 If I end up getting the sign built without a disaster, any stand will be acceptable. Finished the biggest pocket and moved to the second largest, which is on the opposite side of the sign from the other and the CNC just screamed back to the middle of the big one and was going to try to cut it there. Everything runs right in simulation so I have no idea what I have screwed up. Quote
naamanf Posted May 14, 2022 Report Posted May 14, 2022 On 5/14/2022 at 9:51 PM, VPI said: If I end up getting the sign built without a disaster, any stand will be acceptable. Finished the biggest pocket and moved to the second largest, which is on the opposite side of the sign from the other and the CNC just screamed back to the middle of the big one and was going to try to cut it there. Everything runs right in simulation so I have no idea what I have screwed up. Expand Saying that part of the G-code cut right then it went somewhere is shouldn’t have? Quote
VPI Posted May 14, 2022 Report Posted May 14, 2022 Nope. Never started, I stopped it when I saw it go way past the part of the sign it was supposed to be doing and was about to put my street number right in the top part of the lake. Half the sign away from where it was supposed to start. Quote
naamanf Posted May 14, 2022 Report Posted May 14, 2022 Check where you have the origin set in V-Carve and where you have it set on the machine. Quote
VPI Posted May 14, 2022 Report Posted May 14, 2022 Bottom left, just like it was on the lake and everything else as I think it is set once for the whole project. Quote
naamanf Posted May 14, 2022 Report Posted May 14, 2022 On 5/14/2022 at 10:12 PM, VPI said: Bottom left, just like it was on the lake and everything else as I think it is set once for the whole project. Expand If it models right but it’s going somewhere else something isn’t set right. It’s a dumb machine and does what it’s told. Quote
VPI Posted May 14, 2022 Report Posted May 14, 2022 (edited) I am going to turn it off and turn it back on again. It was a full 7.5 inches too Y but the X seemed close. Had it return it it's X,Y Zero and it went right where it was supposed to. Edited May 14, 2022 by VPI Quote
VPI Posted May 22, 2022 Report Posted May 22, 2022 Wrapping up the yard sign with Total Boat Halcyon varnish all day today. The only thing that will not be completely sealed is the sides where they will domino/glue into the 4x4s. Should I varnish the outside edges of the side to keep this waterproof or will a tight glue up with Tb3 be sufficient? 4 Quote
n_maher Posted May 22, 2022 Report Posted May 22, 2022 General rule of thumb (that I've been taught anyway) is that to the maximum extent possible finish all sides of the piece the same. The hope is that it helps to avoid warping/twisting/cracking from uneven moisture absorption or loss. Regardless, it looks great. 2 Quote
naamanf Posted May 22, 2022 Report Posted May 22, 2022 On 5/22/2022 at 1:37 PM, VPI said: Wrapping up the yard sign with Total Boat Halcyon varnish all day today. The only thing that will not be completely sealed is the sides where they will domino/glue into the 4x4s. Should I varnish the outside edges of the side to keep this waterproof or will a tight glue up with Tb3 be sufficient? Expand I would seal it all the same except for the domino holes (if you already made them) and let the TB3 seal those. Make sure you don’t use the beech dominos, they make ones specifically for outdoor/wet use. 2 Quote
swt61 Posted May 22, 2022 Author Report Posted May 22, 2022 (edited) I agree with both the smart men above. Edited May 22, 2022 by swt61 1 Quote
swt61 Posted May 22, 2022 Author Report Posted May 22, 2022 (edited) On a different note, has anyone used Valchromat yet? It has some properties that I could find plenty of uses for. With the color throughout, multiple colors and the resin core, I can see this as a great medium for speaker builds as just one promising option. Also all kinds of shop jigs, tablesaw sleds, sacrificial fences, splining jigs and so many others. Edited May 22, 2022 by swt61 Quote
VPI Posted May 22, 2022 Report Posted May 22, 2022 Good point on the Sipo dominos. Had to order those online as no one local has them. More delays as the cold front we are having here is making everything go really slowly. Garage is hovering around 55 degrees and no heat in the forecast until next weekend at this point. Made pouring epoxy resin a pain in the ass. Quote
naamanf Posted May 22, 2022 Report Posted May 22, 2022 On 5/22/2022 at 5:13 PM, VPI said: Good point on the Sipo dominos. Had to order those online as no one local has them. More delays as the cold front we are having here is making everything go really slowly. Garage is hovering around 55 degrees and no heat in the forecast until next weekend at this point. Made pouring epoxy resin a pain in the ass. Expand Time for a mini-split. I installed a Mr. Cool in mine and so far it’s been great. 1 Quote
swt61 Posted May 22, 2022 Author Report Posted May 22, 2022 Must resist the sexual inuindos in that statement. Having great difficulty! 1 Quote
luvdunhill Posted May 24, 2022 Report Posted May 24, 2022 On 5/22/2022 at 4:21 PM, swt61 said: On a different note, has anyone used Valchromat yet? It has some properties that I could find plenty of uses for. With the color throughout, multiple colors and the resin core, I can see this as a great medium for speaker builds as just one promising option. Also all kinds of shop jigs, tablesaw sleds, sacrificial fences, splining jigs and so many others. Expand Cool. I would love to try that out on a speaker build! Quote
swt61 Posted May 24, 2022 Author Report Posted May 24, 2022 I don't know how it glues up. I believe it is compressed with epoxy, so it may need to be glued together with epoxy. But then it's just a matter of clear coating, or no coat for a flat finish. Quote
Craig Sawyers Posted May 24, 2022 Report Posted May 24, 2022 (edited) The guy in the video runs this outfit https://www.lathamtimber.co.uk/products , and sells a whole lot of interesting decorative products including Valchromat. Different thicknesses and panel sizes. Wonder what the acoustic properties are like? How dead etc. Just seen this on his site "Please note: due to the nature of our business and our delivery vehicles, we are unable to supply to the general public." Edited May 24, 2022 by Craig Sawyers Quote
luvdunhill Posted May 24, 2022 Report Posted May 24, 2022 On 5/24/2022 at 6:11 AM, swt61 said: I don't know how it glues up. I believe it is compressed with epoxy, so it may need to be glued together with epoxy. But then it's just a matter of clear coating, or no coat for a flat finish. Expand I would probably build a open baffle speaker with a full ranger with an integrated h-frame or dipole sub. I have been wanting to try something called a slot load as well: http://www.enjoythemusic.com/diy/0911/slot_loaded_open_baffle_speaker.htm 1 Quote
