swt61 Posted November 18, 2021 Author Report Posted November 18, 2021 Impressive to say the least! 1 Quote
Craig Sawyers Posted November 18, 2021 Report Posted November 18, 2021 Roubo would absolutely have approved of that bench! A thing of beauty. 1 Quote
VPI Posted November 18, 2021 Report Posted November 18, 2021 8 hours ago, naamanf said: A little better, I’ll probably live with it since it’s perfectly function and will remind me what not to screw up. Since you screwed this up so much, I recommend you just throw it all away and start over. Just consider this a practice run. Also, on an unrelated subject, I am doing research on the days peoples’ trash is picked up across Head-Case for a white paper I am writing. Please send me your address and pick-up day for my studies. 4 Quote
VPI Posted November 21, 2021 Report Posted November 21, 2021 My workmanship is about 87k levels below the bench, but getting closer to wrapping up the crate. 10 Quote
naamanf Posted November 21, 2021 Report Posted November 21, 2021 That looks really good, very professional. I don’t think you give yourself enough credit. Quote
VPI Posted November 21, 2021 Report Posted November 21, 2021 Thanks, but it is all the picture angles, if you could see the screw ups, you guys would probably ban me from the thread. 1 Quote
swt61 Posted November 21, 2021 Author Report Posted November 21, 2021 Jeff, if you'd like some decent tutorials, check out The Wood Whisperer on YouTube. He has many varied tutorials for joinery, cabinetry and son on. Quote
VPI Posted November 21, 2021 Report Posted November 21, 2021 Yeah, I watch all those guys. My issues usually arise with equipment, e.g. I have no jointer so I use a sled on the table saw, table saw sled can only accommodate about a 16” board due to the tiny top on the job site so cannot joint, leading to issues. Then don’t get me started on trying to finish a 42x30 crate on plywood sheets on a table in the garage as it is too cold to do anything outside so I could use all the spray equipment piled on a shelf. Quote
swt61 Posted November 21, 2021 Author Report Posted November 21, 2021 Space and tool limitations are my biggest cryptonite as well. If I ever win the lottery, I'll have the biggest, Best stocked shop on the West Coast! 1 Quote
swt61 Posted November 25, 2021 Author Report Posted November 25, 2021 You got those beavers workin' overtime! Quote
Craig Sawyers Posted November 26, 2021 Report Posted November 26, 2021 I somehow read that post completely differently 😆 3 Quote
naamanf Posted November 29, 2021 Report Posted November 29, 2021 Trying to decide on a dust extractor. Leaning toward a Hilti, seems it beats all the rest with a 20year warranty to boot. Or a Festool CT26. Thoughts? Quote
swt61 Posted November 29, 2021 Author Report Posted November 29, 2021 I'm becoming a pretty big fan of the lime green, but I don't think that there's a bad choice between the two. Quote
dsavitsk Posted November 29, 2021 Report Posted November 29, 2021 If you have other Festool stuff, the ability to stack it all on top of the vac is nice. Quote
VPI Posted November 29, 2021 Report Posted November 29, 2021 I think the Festool Vac is the best thing they make. No idea about Hilti, are you talking about their construction wet/dry vacs? I am selling the little sawstop tonight and picking up a PCS tomorrow. Going to sling up some kind of ceiling harness that I can use to Mission Impossible around the garage to use the different pieces of equipment. 1 Quote
naamanf Posted November 30, 2021 Report Posted November 30, 2021 Here is the Hilti https://www.hilti.com/c/CLS_DUST_MGMT_VACUUM_CLEAN_7125/CLS_VACUUM_CLEANERS_ACCESSORIES_7125/CLS_VACUUM_CLEANERS_7125/r11001070 The one nice thing about the Festool is the Bluetooth with the ability to add a button at the end of the hose to turn it on and off. Quote
swt61 Posted November 30, 2021 Author Report Posted November 30, 2021 You can set the Festool to automatic, plug your tool into it, then it'll turn on and off with the tool. Quote
naamanf Posted November 30, 2021 Report Posted November 30, 2021 12 minutes ago, swt61 said: You can set the Festool to automatic, plug your tool into it, then it'll turn on and off with the tool. Not with battery tools 😉 Quote
VPI Posted November 30, 2021 Report Posted November 30, 2021 The Hilti seems nice. Hilti seems to have the auto filter cleaner which I believe does not come with the HEPA filtered Festool. They also mention a BT remote for battery tools but I did not see if that is like the Festool or just a handheld remote. Quote
naamanf Posted November 30, 2021 Report Posted November 30, 2021 Checking out the Hilti. Seems solid and they do have a Bluetooth module in Europe that is just like the Festool, would just have to order from there or wait for it to come here. Choices, feel like I need to make the right decision when buying something that sucks. 2 Quote
VPI Posted December 1, 2021 Report Posted December 1, 2021 Looks decent. I think I like the brakes on the Festool better than that system but the gauge for bag fill and stuff would be nice. Going from the Sawstop Jobsite Pro which just required I pull it out of the box and put the blade on to the new PCS with 20 boxes and having to build the whole thing is quite the adventure. 3 Quote
