What vinyl are you spinning now?
swt61
10 hours ago, robm321 said:
I have that record. It's fantastic.
The reissue?
Speaking of which, been trying to get this particular record sounding better. Been a combo of dial-a-vta on the Tri, cart loading (going from a 100 to 250 ohms on my 40 ohm resistance DL-S1 - the usual recommendation is 10x but I forgot to adjust it from my previous much lower Zyx ... ) but the kicker was needing to clean the record. Well, took the RCM out of the garage where it survived a few Michigan winters and Texas summers over a decade and the reservoir and associated tubing had disintegrated - discovered after of course topping it off with fluid, which meant a torrential downpour of a gentle vinegar smell on top of my record cabinet.
So ordered a new reservoir assembly (awesome that vendors sell serviceable equipment with available parts) and got the Sibelius record cleaned last night and dialed in and I think we are a go. The surface noise is so much better now! The higher cart loading setting is still in judgment phase.
  • Like 4
Nice!
I conducted the same experiment on a really dirty record I'd purchased from Goodwill. I was astonished at the job the VPI cleaner did.
BTW, I'm keeping my eye out for that ultra low Benz.
And I had no idea that Christina Ricci was a double threat?
  • Haha 1
5 minutes ago, swt61 said:
Nice!
I know right? You should hear her version of Bach’s Air on the G String!
Yes, the reissue. I had a problem with my cartridge distorting during dense-complex passages with only this record. I tried adding weight, adjusting VTA, etc., and pretty much gave up on it. Years later after moving and setting up the same cartrige, I decided to try it again. It handled everything without issue. Still have no idea what the issue was before. I've always used a RCM.
Edited by robm321
  • Thanks 1
Interesting - yeah it has a lot of dynamic range. Same phono stage as well?
