Diy Stax-Srd7 for about....hmmm...$20
Hello everyone, hope everything doing very well today.
Few days ago I found two transformers in my dungeon, which named by my wife. I mentioned it has 16V out and double 110V in, so I guess perhaps could make something like stax srd-7.
Then I made a pcb and give most places to voltage doubling rectifier, as same as srd-7, and... it works.
Well somehow the bias unable to reach 580V, only around 490V, the sound quality, of course, bass section bit weak, so I have to turn the EQ on, then everything fantastic.
BOM:
 2 30W transformers 110-0-110 in 16V out, 1 50W transformer 220V in 110V out.
1 fuse @200ma
6 0.1uf 630V caps
1 0.01uf 630v cap
6 1n4007 diodes
4 speaker connectors
2 2M2 resistors @ 2W (for safety consideration no less than 1/2W)
1 15k resistors ( to light up led)
2 5R resistors @5W for dummy load
1 1M resistor
1 stax standard electrostatic can connector
Infact if I could spend enough time on it, hand wired construction must be better and cheaper.
So I call this project "Ghetto SRD-7".
Neat!  When you say your bias is only able to reach 490, how are you measuring that?  You cannot just measure with a normal DMM as it's own impedance will give a false low reading.
And where did you get the board made?  Looks quite nice.
Edited by Blueman2
measured by a high voltage probe of oscillator, yes ,you right, the bias has fallen down when the probe touch the bias connector.
I drawn this pcb by AD11 and made in JiaLiChuang, which has two factories in south of China, cheap and quick.
