Hi All,
I have been going cross-eyed of late poring through the various threads for the projects required to get a complete amp together and hoping to get a few pointers.
I was originally looking at building a Dynalo based amp but after some feedback from Pars and others I had a look at the CFA2/3 boards and think I have decided to go with a CFA3 based build.
I am going to build a balanced in / balanced out setup in dual mono so for the amp boards, it will be 2 x CFA3 (based on 89753654_cfp3rssfixedssw-CADCAM.zip) - I am pretty comfortable that this seems to be the most recent version of the CFA3 board.
Where things seem to get a bit interesting is the GRLV power supply. Reading through the thread, there seems to be quite a few evolutions of this design and a few different ways of completing it. Based on the GDrive archive, goldreference6d.zip seems to be the way to go but looking through the thread for it, there are a number of evolutions of the design since then including a large cap version and options for 6min/6plus, 7min/plus,  79xx/78xx etc etc - the head starts to swim when going through it. Taking a KISS approach, what is the easiest board to build in this regard especially considering effort / perfomance .
Lastly, just to make the build that little more complicated, I am going to go with dual digitial attenuators. My first thoughts were to go with the delta 1 board but then I stumbled upon the digital attenuator designs here by Kevin and Kerry. The through hole version looks easier to make but is a 6 layer board which is not the cheapest to get made in small volume. The SMD version looks better but it is 3 layer which most of the small run PCB houses do not seem to support and from memory there may be a component or 2 that have to be done with a oven / hot air due to solder pads that are not accessible. Should I just stick with the delta1?
Lastly, I am happy to go off and get a bunch of boards made for each however if anyone has any boards they are willing to part with that will definatly steer my decisions. Most board hoauses seem to do qty's of 5 or 10 and with me requiring 2 of everything, 5 is a shitty number as having 1 board left over does not help my minor case of OCD so I will get 10 of each made - I may use 4 of each so will have a few left over if anyone wants any (note, this is not a group buy, once decided upon, I am not going to wait for people before placing an order, I will order them and if anyone is interested down the track I should have some).
Any tips would be appreciated.
Cheers,
Ben
Hi Ben,
I think I have all the versions of the digital attenuator boards including a new design I’ve just finished.
I’ll PM you.
Regards,
 Kerry
  • Thanks 1
It’s great to see more people working on the CFA-3, it should get more attention!
Regarding the GRLV, this is the one I have been using in the Dynalo, Dynahi and forthcoming CFA-3. It’s version .47, dated 2018 with small caps (25mm diameter). I’m not so sure about the name because I downloaded it and renamed to something easier to remember.
Edited by thuytn
Going through the various files and looking at them in a gerber viewer, .47 is goldenreference6drflipto220.zip. .48 seems to be the latest Kevin version which is the goldenreferencelargecap.zip and then v2(?) seems to be the Kevin + Kerry version.
^ The large cap version allows a shorter height board for use in a 1U chassis. The version which thuytn mentions (.47) also uses the to220 schottky rectifiers, and has dual outputs. This is the version I would use unless I needed the shorter height.
Thanks to a few people on here, I managed to dodge getting boards made and managed to buy existing boards for all the bits I need. I am still waiting on a delivery tom come in over the next week or so with the CFA boards and a few other bits and bobs but have received some GRLV boards and a set of v1 attenuator boards and a v2 board.
I have done some SMD work in the past with the soldering iron but thought I would up my game this time round and give a hot air rework gun a go. Kerry sent me 2 v1 attennuator boards - 1 already populated and one bare, as well as all the parts to build it, so I finally pulled my finger out today and built it up -
  • Like 3
I had some parts left over and thought what the heck, I might as well do what I can on the v2 board. I was short a few of the resistors I had so need to get a few extras as well as a few other bits and pieces that differ between the v1 and v2 boards, then need to decide which one I will use - I like the form factor of the v2 board.
After my first couple of hours with the heat gun I have to say I dont mind doing SMD work this way. Once you get some heat into the board the process goes pretty smoothly and the components just latch in to place which is nice.
Now I need to start getting some components together for the GRLV and CFA boards and will then get to work on them.
  • 4 weeks later...
A little more progress - have the first or 2 GRLV's 98% done (at least until I figure out casing and heatsinks)
Mouser were out of a couple of the default resistors so I had to change a couple to higher power (1/4w) which has resulted in a cramped fit for a couple of them but nothing too bad.
Tip for the future - in situations like that look to flip the larger component on the bottom of the board.  As long as you are using standoffs that will allow for clearance to the chassis it ends up with less of a cramped situation and the potential for leads to get closer to things than you would like.
  • Like 5
The main issue was that the resistors were longer than the hole spacing so the leads need to tuck back in to fit - I could have placed the resistors vertical and had the leads hook back over. I still need to order parts for the 2nd GRLV so may order some different resistors as part of that order and swap them out.
19 minutes ago, Pars said:
Those are 500R? 499R is the standard value (E96?) in that series and should be readily available.
There is an issue with the 10k, 500R, and 2k resistors. They are all too big for the hole spacing. Interestingly, I just rechecked the BOM you posted on the gold reference thread back in April and it lists all 1/4w resistors, so not sure what has happened here.
Looking a bit deeper, for the values where I could not get a direct hit on part number, I moved to 25ppm (default was 100ppm), same series (RN) same resistance and same wattage (1/4w) but guess the lower ppm results in a larger body which I had not paid attention to. Live and learn . . .
Those look like RN65s. The RN60Ds are 1/4W rated (Mil Spec) but are actually 1/2W. The PPM rating should not have anything to do with physical size.
Edited by Pars
Well spotted. Went back and checked what I ordered, and yes, RN65's - RN60's were not available for those 3 items . It does say on the spec for each item that they are physically larger, I just missed it at the time, I looked at resistance and wattage and figured same same at the time. I think I was swimming in BOM's with GRLV, CFA and 2 versions of DA to build a list for that I was getting a bit cross-eyed late in the night and missed it.
  • 1 year later...
Has been a bit of a while between updates on this one - I got a bit sidetracked with things to say the least!
I finally pulled my finger out a few weeks back and got back onto this project. It has been fun trying to source parts in the current climate but I have managed.
I am frustratingly close to getting the main components finished - I have 2 (actually 4 now) GRLV's built, all running within .005v of each other and each rail and I also have the majority of the 2 x CFA3 boards finished. I stuffed up on my last mouser order and ordered 300k Ohm resistors instead of 300 Ohm resistors - the downside to ordering things late at night! I also forgot to order a couple of other resistors so as it stands at present, I am about 6 resistors per board away from having the CFA boards complete.
I also have the v1 digital attenuator boards finished and ready to go so that leaves the protector board and the ZF / SS board to go which should be pretty straight forward (although the relays for the switching board are getting hard to obtain).
I also need to build a seperate power board for the ancillaries - the attenuators, motorised pot to control the attenuators and the switching board all require a combination of 12v, 5v and 3.3v so I think I am going to build a L-Adapter power supply to supply 12v to feed the relays and also feed that into a voltage reg circuit I have built myself for the 5v and 3.3 for the rest of things. It means I will have 3 power supplies in the PSU case along with 3 transformers etc but hey-ho.
I have pretty much settled on the Takachi HY series enclosures for the PSU and Amp chassis - whilst I can fit the PSU in a slightly smaller footprint than the amp, I have decided to get them both in the same footprint just different heights - taller for the PSU and shorter for the amp / attenuator / pot / switching. They are not the cheapest chassis out there but not much more than most of the other options and a bit higher quality looking in my opinion.
It would appear that my account is only allowed to post another 116kb in images to this thread so it is not possible to post any pics but will post an update in the next week or so once the boards are complete.
Update - managed to sort out a way to host images so I can now insert them without worrying about quota - this is the chassis I am looking at going with (minus the UpTone Audio stuff....) -
Edited by bdinnev
Images
Finally received the last of the components for the CFA boards today from DigiKey - Mouser who I usually use were out of a couple of items and whilst DigiKey had the values I needed, they didnt have them in RN60 so ended up going for the slightly more expensive CMF series resistors - was only for a few values so was not a big deal and am happy to have everything in now.
Some quick soldering and the CFA3 boards are finished (except for the output transistors - they will go in when I have the cases and heat-sinking sorted out) - has been a long time between start and finish but I can feel the end of this build getting near.
PS, managed to find a free way to host images - Google Firebase - so can now insert images without having to worry about chewing up quota :)
  • 2 months later...
Looking nice!
Are you going to bolt the pass transistors on the GRLVs to the heatsinks on the side of the case? They will need some cooling.
First powering and adjusting the amp should be without the OPAs, so you can take them out for now.
For the CFA3, I would advise to consider the headphone protector as well, which is pretty much a must for dynamic cans. It connects to Vcc+ of the amp and makes its own 12v out of a 7812 which is 1A and if you use a couple of low signal switching relays on the inputs, you can tap into it without the need for another transformer and voltages in the PSU.
Edited by audiostar
On 4/9/2022 at 12:49 AM, audiostar said:
Looking nice!
Thanks audiostar. Yes, the transistors on the GRLV's will be mounted on the heatsinks on the side of the case - I temporarily soldered them into the boards just so I could do some quick tests on the GRLV's to make sure there was not any unwanted smoke etc but will remove the transistors and then re-mount them onto some aluminum angle which will then be mounted to the case heatsinks and solder them back into the boards.
I have a headphone protector board ready to go as well as a pair of the 1st gen digital attenuators and a ss / zf switcher board. I am going to be running 3 transformers in the PSU - 2 x 24v 100va for the GRLV's and 1 x 15v 50va a to run the headphone protector, DA's, DA controller and ss / zf switcher along with 2 linear power circuits for 12v and 5v. I know it is a bit of overkill but I have space for it so figured why not.
I need to go back and read the main thread for the CFA's to wrap my head around adjustment as it has been a while since I started this project. I will hopefully have the case for it in the next couple of weeks and once it is all cased up will get around to adjustments etc.
  • 3 months later...
