NotoriousBIG_PJ Posted June 19, 2007 Report Posted June 19, 2007 I was wondering if anyone knows what type of material is used for the inside tube of the z-sleeve? The outside looks like a giant piece of heatshrink. And the inside is some type of tube, but what kind of material and where could I buy tubing like this? http://www.6moons.com/audioreviews/zcable1/sleeve.html Thank you, Biggie Quote
Augsburger Posted June 20, 2007 Report Posted June 20, 2007 When I read this article a while ago I did some research based upon various clues given in the review. I forgot what most of them were but I eventually determined that the "tube" is probably a ferrite bead. I made some enquiries all over the net and the only company that had anything comparable was: http://www.ferrishield.com/ They will do custom sizes similar to the ones in the Six Moons article but very expensive. They quoted me about $500 if I recall. What is interesting is that the Z sleeves are used with ICs and speaker cables in the Six Moons article, yet most other uses for audio equipment that I have seen only specify ferrites use with power cords. Quote
NotoriousBIG_PJ Posted June 20, 2007 Author Report Posted June 20, 2007 I highly doubt there is anything ferrite in the z-sleeve. Just by guessing I would think its some kind of plastic tube. It needs to be something that lets emi/rfi through it and maintains it's cylindrical shape and is cheap. I made a diy version with pipe insulation, but the insulation is prety thick and its not all that durable because it is cut straight down the middle. Biggie. Quote
Augsburger Posted June 20, 2007 Report Posted June 20, 2007 I didn't explain very well before, how about -http://www.claritycable.com/Z-Sleeves.html equals- http://www.ferrishield.com/html/ferrites/emcshieldingfabrics.html That is what I meant. If that dosen't work, then I give up. Quote
NotoriousBIG_PJ Posted June 20, 2007 Author Report Posted June 20, 2007 I'm not interested in whats inside the z-sleeve, I just want to build a similar casing. Biggie. Quote
aerius Posted June 20, 2007 Report Posted June 20, 2007 I'm not interested in whats inside the z-sleeve, I just want to build a similar casing. Biggie. Go to Canadian Tire or Home Depot. They should have some large diameter clear vinyl (I think) tubing. Grab some of that, grab some foam pipe insulation to go around it, then get some PVC or ABS pipe that fits over the foam. Glue it all together & paint it and you'll have one of those swanky cable doo-hickeys. Quote
NotoriousBIG_PJ Posted June 21, 2007 Author Report Posted June 21, 2007 Word, I'll see what I can find. Do you know where I can buy large ass diameter heatshrink? Thanks, Biggie. Quote
aerius Posted June 21, 2007 Report Posted June 21, 2007 Nope, the largest I've seen around here is either 1" or 1.5" diameter. Quote
JBLoudG20 Posted June 21, 2007 Report Posted June 21, 2007 https://www.wirecare.com/products.asp?prodline=H2 3" Quote
NotoriousBIG_PJ Posted June 22, 2007 Author Report Posted June 22, 2007 Dang, the big stuff is pretty expensive. Thanks for the link. Biggie. Quote
JBLoudG20 Posted June 22, 2007 Report Posted June 22, 2007 LOL Holy crap, I didn't look at the price. I bought some 2" one time, didn't realize I paid that much. Quote
NotoriousBIG_PJ Posted July 8, 2007 Author Report Posted July 8, 2007 I went to Home Depot today and they had nice plastic tubes 1 1/2 inch and 2 inch. 1 1/2 inch is too small for power cord barrels, and 2 inch is too large for my heatshrink. I need to find some 1 3/4 inch stuff doh. Biggie. Quote
