fireworks Posted July 25, 2019 Report Posted July 25, 2019 Anyone has experience with the Ebay kits for the KGSSHV Carbon: https://www.ebay.com/itm/Power-supply-PCB-for-KG-Kevin-Gilmore-KGSSHV-CARBON-Electrostatic-amp-L9-50/123415369465 and https://www.ebay.com/itm/Kevin-Gilmore-KGSSHV-CARBON-Electrostatic-Headphone-amplifier-bare-PCB-L8-39/123327894674 The names contain "L9-50" and "L8-39": are these version numbers ? I'm interested in building a KGSSHV Carbon and any help is appreciated.
kevin gilmore Posted July 25, 2019 Report Posted July 25, 2019 (edited) power supply is version 1.8 copyright 2015 however it shows both boards the same, and that is definitely not the case. although you can do it that way, but then you need a grlv power supply in addition one board has the bias voltage, the other board has the low voltage regulators amp is version .6 copyright 2015 I think this is the latest I released. There is a .61 version which I may or may not have released, don't know the differences Edited July 25, 2019 by kevin gilmore 1
Makoto Posted March 20, 2020 Report Posted March 20, 2020 On 7/26/2019 at 1:13 AM, kevin gilmore said: power supply is version 1.8 copyright 2015 however it shows both boards the same, and that is definitely not the case. although you can do it that way, but then you need a grlv power supply in addition one board has the bias voltage, the other board has the low voltage regulators amp is version .6 copyright 2015 I think this is the latest I released. There is a .61 version which I may or may not have released, don't know the differences It seems the boards to be kind of thin.. btw me,newbie, making my first KGSSHV and KGSSHV mini and having seen many Kevin-designs, find that there are many circuits with LSK389. I learnt that there are LSK389 A,B,C,D. Could you tell me which one to choose or they are the same? with much thanks!
Pars Posted March 20, 2020 Report Posted March 20, 2020 B normally... the equivalent of the Toshiba BL grade.
Makoto Posted March 21, 2020 Report Posted March 21, 2020 14 hours ago, Pars said: B normally... the equivalent of the Toshiba BL grade. got it. Thanks!
