spritzer Posted April 12, 2019 Report Posted April 12, 2019 ....so I bought one of these. They popped up on Massdrop while I was talking to Kevin who immediately called BS on this. My curiosity peaked, I had to get one. Here is the product page: https://www.bursonaudio.com/products/supreme-sound-opamp-v5i/ BS meter is tingling so I waited for it to arrive: Nice enough box and here are the internals: I forgot to take a picture of the top but it looks exactly as it did on the page. Here is the bottom though: The potting compound is pretty soft so here is what I found: So... the only thing in there is an opamp with the top markings sanded off and one small cap. There is nothing on the bottom, just this. We have no idea what opamp that is but it would be pretty simple to dissolve the resin and look at the die. I very much doubt this is some custom one off unit, why would they sand off the top if it was some custom device? Also, why is that cap there? I mean this is a dual opamp so two channels and two power rails...why one cap? This reminds me of the Single Power tube adapters, they had parts for just one section of the dual triodes...why I just don't know. 2
jose Posted April 12, 2019 Report Posted April 12, 2019 I´m not sure why but for a moment Birgir remid me at Bob Widlar...
Pars Posted April 13, 2019 Report Posted April 13, 2019 The cap is probably the erroneous V+ to V-... Yours doesn't have all the magical components touted in the marketing hype?
Emooze Posted April 13, 2019 Report Posted April 13, 2019 (edited) The cap has a tolerance measured in pF with no total value but the resistor has a percentage. I'm still even more confused though, what are the resistors for now? Does it have a built in feedback loop? Is it a weird op-amp like a 701 that needs external components? I know you all don't have the answers I need, I'm just tired and instead of going to bed, I am here. Edited April 13, 2019 by Emooze
spritzer Posted April 13, 2019 Author Report Posted April 13, 2019 (edited) Cap tolerance is often in pF for low value caps or precision ones but there are none here. The pinout is standard for a dual opamp and the cap is 118nf measured between V+ and V-. That's all the "magic" here. Edit: Yeah no resistors or anything like that. I also like the "custom pins" they tout as they are just the normal sockets turned upside down... Edited April 13, 2019 by spritzer
swt61 Posted April 13, 2019 Report Posted April 13, 2019 I updated my DIP8 connector for a DIP10 when I was 12. Just sayin'.
sorenb Posted April 13, 2019 Report Posted April 13, 2019 1 hour ago, swt61 said: I updated my DIP8 connector for a DIP10 when I was 12. Just sayin'. ...sure it wasn't ZIF10?
Mirko Posted April 13, 2019 Report Posted April 13, 2019 @spritzer Did you listen to it, how does it sound? 1
spritzer Posted April 14, 2019 Author Report Posted April 14, 2019 Why on earth would I do that? I don't think I even own anything that uses opamps unless you are counting servo's.
