JoseA Posted March 17, 2020 Report Posted March 17, 2020 I would like partially assembled boards for one set Thank you Quote
gepardcv Posted March 18, 2020 Report Posted March 18, 2020 Please increase my order of both GRLV78 and GRLV79 to 5. Also please add 2 bare GRHVs because they're cheap and why not. Quote
Energy Posted March 18, 2020 Report Posted March 18, 2020 I would like one bare set please. Thank you! Quote
MLA Posted March 18, 2020 Report Posted March 18, 2020 Please increase my grlv78/79 to 6 each instead of 3 each. Thanks!!! Quote
mwl168 Posted March 18, 2020 Author Report Posted March 18, 2020 (edited) 10 hours ago, Energy said: I would like one bare set please. Thank you! Please read the thread and be specific about which boards you want and how many. On 3/17/2020 at 12:12 AM, JoseA said: I would like partially assembled boards for one set Thank you Please be specific. Table updated. Edited March 18, 2020 by mwl168 Quote
mwl168 Posted March 18, 2020 Author Report Posted March 18, 2020 GR78 and GR79 BOM added to first post. Quote
jamesmking Posted March 18, 2020 Report Posted March 18, 2020 (edited) mwl168, I had a look at the bom for the gr78xx and tried to build a mouser project from it. However mouser says the kst42mtf is obsolete and out of stock. Also C3 C7 in the bom is the same as c1 and c2 but is on a seperate line... the gr79xx also uses the obsolete kst42mtf. the gr79xx also has two entries for the same cap, c1,c4 and the line c7. Ok looks like farnell still has some stock remaining.... Edited March 18, 2020 by jamesmking Quote
MattN Posted March 18, 2020 Report Posted March 18, 2020 Just to confirm that I would like what is listed against my name in the table. Thanks! Quote
Orso_Aquilano Posted March 18, 2020 Report Posted March 18, 2020 Hi sorry for the delay but quite busy down here curing people with that damn virus (not infected yet !!! thanks to my own protection hardware ....) i will double the order so 2 sets , that would be 4x GRHVxxx (assembled) 2x GRLV78xx 2x GRLV79xx 2x main board 2x mini t2 board Right ?and obviously i confirm the participation Quote
JoseA Posted March 18, 2020 Report Posted March 18, 2020 Hi, Sorry, to be more precise: 2x GRHVxxx (assembled) 2x GRHVxxx. Bare 2x GRLV78xx 2x GRLV79xx 2x main board 2x mini t2 board Thanks Quote
mwl168 Posted March 18, 2020 Author Report Posted March 18, 2020 (edited) 2 hours ago, jamesmking said: mwl168, I had a look at the bom for the gr78xx and tried to build a mouser project from it. However mouser says the kst42mtf is obsolete and out of stock. Also C3 in the bom is the same as c1 and c2 but is on a seperate line... the gr79xx also uses the obsolete kst42mtf. the gr79xx also has two entries for the same cap, c1,c4 and the line c7. C1, C2 and C3 are different values. A quick look seems CMPTA42 could be a pin/package compatible part for KST42. Same goes for the PNP part. Kerry and others should be able to confirm. Table updated. Edited March 18, 2020 by mwl168 Quote
Energy Posted March 18, 2020 Report Posted March 18, 2020 Apologies for not being accurate. 😅 I'd like the following: (enough for one Mini T2) 2x GRHVxxx (bare) 1x GRLV79xx 1x GRLV78xx 1x Main Board 1x miniT2 Quote
khadis Posted March 19, 2020 Report Posted March 19, 2020 2x mini T2 board 2x PSU main board 2x GRLV78 2x GRLV79 4x GRHVxxx (bare PCB) 2x GRHVxxx (partially assembled) Quote
samsie Posted March 19, 2020 Report Posted March 19, 2020 Please update my order. 4x GRHVxxx (assembled) 6x GRLV78xx 6x GRLV79xx 2x main board 1x mini t2 board Thanks Sam Quote
Kerry Posted March 20, 2020 Report Posted March 20, 2020 On 3/18/2020 at 5:12 PM, mwl168 said: C1, C2 and C3 are different values. A quick look seems CMPTA42 could be a pin/package compatible part for KST42. Same goes for the PNP part. Kerry and others should be able to confirm. Table updated. I think I've used MMBTA42/92 in the past successfully, though your suggestion Michael looks like it should work as well. Quote
judo Posted March 20, 2020 Report Posted March 20, 2020 Kerry, the GRLV78/79xx can be usable in your dynalo mini ? Quote
mwl168 Posted March 20, 2020 Author Report Posted March 20, 2020 (edited) We have a few new comers to HC (<= 10 posts) that participated in this GB and have not responded to my inquiries, including direct PM, for confirmation. We need final board counts to get accurate quotes from the fab house for this GB to proceed. The GB participants listed below please respond on this thread with your confirmation or desire to drop out by end of day this coming Sunday, March 22. If we do not receive your response , I will assume you are no longer interested and will remove you from the GB. Thanks! stickyjon23 grendel23 zumac99 Marc Edwards Edited March 20, 2020 by mwl168 Quote
G600 Posted March 20, 2020 Report Posted March 20, 2020 Thank you for your time Michael. This GB is hot! Quote
grendel23 Posted March 20, 2020 Report Posted March 20, 2020 I am still in for: 4 ea. GRHVxxx partially assembled, 2 ea. GRLV78xx, 2 ea. GRLV79xx, 2 ea. main board, 1 ea. mini T2. Thanks, Jay Quote
mwl168 Posted March 20, 2020 Author Report Posted March 20, 2020 Table updated. GR78 and GR79 BOM updated. Quote
Makoto Posted March 20, 2020 Report Posted March 20, 2020 Hi Michael, hoping that I'm not too late, I would like to have 2x GRHVxxx 1x GRLV79xx 1x GRLV78xx 3x Main Board 3x miniT2 with much thanks! Quote
judo Posted March 21, 2020 Report Posted March 21, 2020 Dear Michael, increase my GRLV78 XX, GRLV79xx numbers to 3 each from 2, please! Thanks!!, no more changes. Quote
mwl168 Posted March 21, 2020 Author Report Posted March 21, 2020 (edited) 4 hours ago, Makoto said: Hi Michael, hoping that I'm not too late, I would like to have 2x GRHVxxx 1x GRLV79xx 1x GRLV78xx 3x Main Board 3x miniT2 with much thanks! Do you want the GRHVxxx partially assembled or bare boards? I assume you know the PSU Main board is designed specifically to work with the GRHVxxx boards? Each main board takes 2 GRHVxxx boards to supply a set of +/- HV rails. Edited March 21, 2020 by mwl168 Quote
Makoto Posted March 21, 2020 Report Posted March 21, 2020 5 hours ago, mwl168 said: Do you want the GRHVxxx partially assembled or bare boards? I assume you know the PSU Main board is designed specifically to work with the GRHVxxx boards? Each main board takes 2 GRHVxxx boards to supply a set of +/- HV rails. It's good for newbie to have the advice. I'd take the bare boards, then 6x GRHVxxx3x GRLV79xx3x GRLV78xx3x Main Board3x miniT2 Thanks! Quote
