Caps in bias supply
Hello,
I would like to inquire about "caps in the bias supply" for Stax headphones.
Spritzer and others said several times that "caps should not be used after the ballast resistor"
(for example here:
In this quoted case it refers to a cap in parallel after the ballast resistor.
In other places the same is said about the cap in series, after the ballast
What problems does the cap cause exactly, in that position?
May I ask an opinion about the attached "blinker" circuit (with a series cap...), of which I read a long time ago;
I have used one like this for a long time "without adverse effects" (or I think so), but I'd like to check about the dangers of a series cap.
The theory of the circuit is, if my understanding is correct, that as long as the diaphragm is sufficiently charged, there is no voltage difference on the two sides of the cap; when the diaphragm loses charge, the neon will conduct and recharge it, and blink while it does this (which adds a nice effect - and too fast a blinking is a sign of charge being lost too fast).
Thanks.
We've gone over this numerous times but storing any amount of energy after the ballast resistor can make arcing much worse than it would be otherwise.  Normally arcing shouldn't be destructive unless something extreme happens.
The schematic you posted looks like the ESL63 design which is very old at this point and Stax were even placing caps after the ballast back in '82.
Ok, I understand.
Thanks for the reply.
