anorphirith Posted June 20, 2018 Report Posted June 20, 2018 I'm trying to make a Super Symmetry Dynahi (not dynalo) the best possible way. (without getting in the ridiculous). Anyone could direct me to the up to date gerber files, a BOM, any other resources are also appreciated. Also if any of you previous builders have recommendation on best practices and what to avoid while making the susy please share ! Thanks Quote
gepardcv Posted June 21, 2018 Report Posted June 21, 2018 (edited) Have you already gone through the existing Dynahi thread? There will be some dead links, but using the search function will get you pretty far. https://www.head-case.org/forums/topic/9768-kg-balanced-dynahi-build-discussion-thread/?tab=comments#comment-468974 Edited June 21, 2018 by gepardcv 1 Quote
Pars Posted June 21, 2018 Report Posted June 21, 2018 I've got a set of boards that I would let go. I'll have to check what version they are. 1 Quote
anorphirith Posted June 22, 2018 Author Report Posted June 22, 2018 update: I've found an up to date gerber but I'm still looking for a BOM, the one in the thread is out of date. let me know ! thanks Quote
gepardcv Posted June 22, 2018 Report Posted June 22, 2018 I usually make my own BOMs following the board silkscreens. That way it'll definitely be up-to-date. The only non-obvious parts I remember are the LED, so use LTL-307ELC. 1 Quote
anorphirith Posted July 1, 2018 Author Report Posted July 1, 2018 update ! Pars was gracious enough to supply me with v1.5 boards, I'll hoping sbelyo will have leftover power boards after the GB ships. I also found a SuSy Dynahi made in 2013 with V1 amp boards and a fancy diy relay based attenuator that's apparently broken (the sound is stuck at a particular level) So I'll be tinkering with that one before assembling my own. larger photos here https://imgur.com/a/YRCZnTI? If anyone sees obvious defects or bad practices or things I could check for let me know ! Quote
kevin gilmore Posted July 1, 2018 Report Posted July 1, 2018 that is amb's step attenuator setup and should be fairly easy to fix. 1 Quote
Pars Posted July 3, 2018 Report Posted July 3, 2018 As Kevin said, probably not too hard to fix. Needs a lot of attention to the wiring in there though, starting with the transformer leads. Quote
anorphirith Posted July 3, 2018 Author Report Posted July 3, 2018 5 hours ago, Pars said: As Kevin said, probably not too hard to fix. Needs a lot of attention to the wiring in there though, starting with the transformer leads. I'm guessing it's one of the relays that have failed, I'm receiving the amp next week, I'll check all that what do you recommend on the wiring ? Quote
jose Posted July 3, 2018 Report Posted July 3, 2018 If you allow me, I would do all the wiring again. I don´t like having everything disorganized. There are many wires that cross, are very long or are placed directly on some components. 1 Quote
anorphirith Posted July 3, 2018 Author Report Posted July 3, 2018 5 hours ago, jose said: If you allow me, I would do all the wiring again. I don´t like having everything disorganized. There are many wires that cross, are very long or are placed directly on some components. Thank you, that was my first order of business, it is actually the first DIY I've seen that's so messy, I don't understand why he took the care to add an R2R attenuator and didn't take the time to fix the wires, he probably lost interest at some point. Which wires are best suited for the re-work (model/brand) ? I was hoping to have help with upgrading something more subtle like maybe changing the resistors with some that have better tolerance or checking certain bias / voltage to make sure everything is fine ? I do have a couple questions: Is that SS relay is for the remote control ? what's the small toroid transformer vertically attached to the case for ? what is the unpopulated section of the power board for ? thanks Quote
jose Posted July 3, 2018 Report Posted July 3, 2018 (edited) For me it is difficult to distinguish anything. Resistors look like Vishay RN60. I don´t think they deserve to be changed unless some are burned. Wires, I don´t use anything specific, just a cable with an adequate thickness and a good dielectric. For the audio signal I sometimes use shielded wire (for microphones or music instruments) sometimes I use Mogami, Canare or just the one available in the electronics/music instruments store of my city…. nothing esoteric. Edit: This is my opinion. Obviously you can use the material you think is appropriate. Edited July 3, 2018 by jose Quote
luvdunhill Posted July 4, 2018 Report Posted July 4, 2018 The brackets need to be better secured to the heatsinks. Is there a screw head on the fin side of the heat sink, or a blind hole with a threaded post attached? Quote
