kevin gilmore Posted December 2, 2017 Report Posted December 2, 2017 (edited) so pars posted this. http://www.diyaudio.com/forums/group-buys/315474-pure-tube-es9038pro-9028-9018-akm.html#post5259820 all sorts of wrong. lets start with the fact that current output D/A converters really like driving a zero impedance. 27 ohms is not a zero impedance. So with +/-1.2ma you get +/-32mv and then you use the tube to amplify the crap out of it. Nope, definitely not the way to do this. All sorts of noise etc... a while back there was bakoon and audio-gd pointing fingers at each other as to who designed satri and when. so here is the satri version 4 circuit satriic.PDF and here is how audio-gd turns it into both the I/v converter and acss current output and voltage output (one at a time, not both) audiogdiv2.PDF performs better than anything else I have seen ideas in progress as work on the ultimate dsd/r2r dac Edited December 2, 2017 by kevin gilmore 4 Quote
nopants Posted December 2, 2017 Report Posted December 2, 2017 which unit of theirs is this? I like the massive decoupling Quote
kevin gilmore Posted December 2, 2017 Author Report Posted December 2, 2017 this one http://www.audio-gd.com/Pro/dac/RE52/RE5.2EN.htm around 2013 time frame. very nice sounding piece, but no dsd Quote
Whitigir Posted December 3, 2017 Report Posted December 3, 2017 14 hours ago, kevin gilmore said: ideas in progress as work on the ultimate dsd/r2r dac Does this mean what I think it means ? Quote
A_Zero Posted December 5, 2017 Report Posted December 5, 2017 Using Resistors as passive I/V stage? Rumors are that it measures really bad, but sounds somewhat clearer and more natural than an active IV stage. Of course the resistor has to be of low noise, high precision type. Quote
