So I've been looking at a bunch of tube/solid state hybrid dynamic amp schematics, and every one of them is some form of bad, or really bad. (one person/ex company in particular)
Low voltage plate, capacitve coupling of a high impedance source into a low impedance, poor balance etc.
There had to be a better way. true balanced input. dc coupling. low impedance output. no feedback. proper use of a tube (pure transconducance) etc
so I came up with this, work in progress.  4 x 3 inches
ubaltobaltubeschem.PDF
Edited by kevin gilmore
  • Like 15
Looks a lot like the front end of an electrostatic headphone amp (T8000-ish), but with relatively low voltage transistors (except for the KSA1156).  You could always substitute a MOSFET current source for the input tube tail CCS. :D
Edited by JimL
  • Haha 1
If I am going to drive high independence headphones with this, what should I do?
1) add triple darlington stage like tubehybrid/CFA did
2) add paralleled darlington stage like dynahi
Edited by joehpj
The filaments don't come from a common source, each has their own regulator. This makes sense because filaments require a lot of current. B+ is pretty low current so just one for both channels should be fine.
  • 5 months later...
Since this is probably the first thing I will try from the group buy I wondered about the transformer and the VA. Looking at the input ac like this would couple 2 cheap transformers work? The +-15 is from a GRLV or something I guess or would a LM317+LM337  do the job?
Gonna build this from the group buy soon,
On the board the silkscreen says "tube mounts on the back side of the board" but tracing the boards shows it's the same version as the one in first post. So tubes should be mounted from the top?
I also have never built tube amps so I might be wrong.
some questions I have:
1. How hot is the mosfet on PSU will be? Will heatsinking with chassis floor (3mm aluminum) suffice or does it need heatsink?
2. LT1085 require heatsinks or not?
3. Will it make a good preamp? Do I need to watch/match it's output impedance to the amp's input?
4. How to bias it?
here are both of them, not sure which one was in the group buy
3)  Its a current mirror. So output voltage depends on impedance, currently 1100 ohms. Needs an output buffer if you are going to use it for a preamp.
  • Thanks 2
  • 4 weeks later...
  • 5 weeks later...
Kevin, can I use the Diamond output buffer ver. 2.0 ?
  • 9 months later...
Dear Kevin,
I find the heater power supply portion to be rather handy.
Would you please  cut the HV supply portion away so  that I can use the heater power supply portion for mini T2 project?
Thanks
Sam
On 11/13/2017 at 7:45 AM, kevin gilmore said:
board files for you :D
updated including 100v massive overkill power supply
ubaltobaltube.zip
grhv100v.zip
Edited by samsie
  • 5 months later...
  • 3 years later...
Can anyone confirm if I can use a 100V secondary trafo for the grhv100? Will it still regulate down to 100vdc without issue? Having a hard time finding a suitable 90V unit that isn't 1A+/huge.
