shellylh Posted June 9, 2017 Report Share Posted June 9, 2017 Looking to get a single portable induction cooktop since I am tired of cooking on the crappy electric stove in my apartment. I have several cast iron pans that I use so there should be no problem switch. Anyone have any suggestions? Do a quick look, there seems to be the HC version (at $1,800) but maybe I don't need quite that much precision. It is very tempting though! https://www.brevilleusa.com/collections/commercial/products/the-control-freak?variant=34041893841 There is also one for $60 that they recommend here: http://thesweethome.com/reviews/best-portable-induction-cooktop/ Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted June 9, 2017 Report Share Posted June 9, 2017 Before I got the Wolf oven/cooktop, I used a single burner cheap thing. Worked great. make sure you try a magnet on the pans you plan on using, some kinds of stainless pans are non magnetic and will not work. also they use 80% of the power of a typical kitchen circuit, so you can't use most other things at the same time 1 Quote Link to comment Share on other sites More sharing options...
MexicanDragon Posted June 9, 2017 Report Share Posted June 9, 2017 Ask Colin, he uses one a bit. We enjoy the recs of The Sweet Home.**BRENT**Sent from my ONEPLUS A3000 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Augsburger Posted June 9, 2017 Report Share Posted June 9, 2017 We have had similar interests since we travel so much for fencing tournaments and Lance is highly allergic to a lot of foods so cooking for him is the only option. https://smile.amazon.com/gp/product/B01FLR0ET8/ref=ox_sc_sfl_title_36?ie=UTF8&psc=1&smid=A2EPN08Z0FPLG4 Note, I believe all pans used with induction cook tops must be magnetic- "Induction cookware must be made of a magnetic-based material, such as cast iron or magnetic stainless steel. Fully clad cookware brands, such as All-Clad Stainless, Viking Cookware, and Mauviel M'cooks stainless work on induction cooktopsbecause they're magnetic." Cast iron pans should work but it wouldn't hurt to check. Quote Link to comment Share on other sites More sharing options...
grawk Posted June 9, 2017 Report Share Posted June 9, 2017 costco sells one that looks like a good deal, if you're a member. 1 Quote Link to comment Share on other sites More sharing options...
Grahame Posted June 9, 2017 Report Share Posted June 9, 2017 Costco $70https://m.costco.com/Tramontina-3-piece-Induction-Cooking-System.product.100319914.htmlSweet home recshttp://m.thesweethome.com/reviews/best-portable-induction-cooktop/ Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted June 11, 2017 Report Share Posted June 11, 2017 Before I got the Wolf oven/cooktop, I used a single burner cheap thing. Worked great. make sure you try a magnet on the pans you plan on using, some kinds of stainless pans are non magnetic and will not work. also they use 80% of the power of a typical kitchen circuit, so you can't use most other things at the same timeIs the Wolf an integrated cooktop and oven? Looking for something like this as I can't really do the counter work to move to "separates". Quote Link to comment Share on other sites More sharing options...
swt61 Posted June 11, 2017 Report Share Posted June 11, 2017 ^ http://www.subzero-wolf.com/wolf/ranges/induction-range Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted June 11, 2017 Report Share Posted June 11, 2017 yep, and requires 60 amp circuit 220v Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted June 11, 2017 Report Share Posted June 11, 2017 yep, and requires 60 amp circuit 220v Looks nice, but the depth is a bit non-standard. Does it stick out a bit from your cabinets in an annoying way? Quote Link to comment Share on other sites More sharing options...
swt61 Posted June 11, 2017 Report Share Posted June 11, 2017 All of the Wolf ranges, as well as Viking and many other professional ranges, stick past the cabinet faces. Not sure the reasoning, but I'd imagine something to do with heat transfer? Maybe to reach an oven depth standard? Quote Link to comment Share on other sites More sharing options...
grawk Posted June 11, 2017 Report Share Posted June 11, 2017 Or to draw attention to its difference Quote Link to comment Share on other sites More sharing options...
guzziguy Posted June 11, 2017 Report Share Posted June 11, 2017 Ding ding ding ding. We have a winner! Quote Link to comment Share on other sites More sharing options...
kevin gilmore Posted June 11, 2017 Report Share Posted June 11, 2017 looks fine to me, the oven door is no more than 2 inches in front of the cabinet faces. The previous oven which was a built in was probably 1 inch in front of the cabinet face all the heat goes up the back splash and under the feet of the oven out the front. favorite place of the dogs when the oven is on. Quote Link to comment Share on other sites More sharing options...
spritzer Posted June 11, 2017 Report Share Posted June 11, 2017 Awww now you made me miss the pups... Quote Link to comment Share on other sites More sharing options...
Hennyo Posted June 12, 2017 Report Share Posted June 12, 2017 (edited) Stovetop recs rec'd! Edited June 12, 2017 by Hennyo Quote Link to comment Share on other sites More sharing options...
cetoole Posted June 13, 2017 Report Share Posted June 13, 2017 I have the sweet home recommended duxtop and do not use my coil stove at all. Yuge upgrade. 3 Quote Link to comment Share on other sites More sharing options...
swt61 Posted June 13, 2017 Report Share Posted June 13, 2017 2 Quote Link to comment Share on other sites More sharing options...
