One request Kevin, if this is applied to the GG circuit layout some day.
If possiblewould be nice if the PCB height could be kept within 130mm/5-1/8 inch max.
58 minutes ago, kevin gilmore said:
looks like the best I can do is about 5.7 inches
current gg board is 4.7 inches
Thanks for taking the time to look into that, Kevin.
Will gladly work around the larger dimension on my end (new cases) when this new tube input GG happens.
Got a gut feeling this will be a killer amp!
far too many projects to keep up, but it's always so tempting once you see the artwork...
i remember reading that kevin was championing the el34 ccs in the megatron, should wire that in instead so everyone gets the tube complement they want even if it's not the grounded grid output. kidding of course, even if it does sound monstrous.
I was thinking to build one adjustable DC supply to use some P88CC or 6N23P. Those have much more reasonable prices.
Filament will sit a little bit at negative. So negative LDO is preferred?
Looking good @JoaMat :)
Here's the new schematic with the updated servo.
It would be very much appreciated if some folks could check Kevin's boards against this schematic.  Thanks :)
EDIT:  Updated schematic to match transistor values.
Edited by Kerry
  • Like 4
Great,
a new version of offset servo. I can’t remember how many versions we have seen so far, but as I remember one of the first was found in Kerry’s KGST (and Stax T2 of course).
minor differences: board looks good, don't see any problems
board uses resistor + zener string instead of U10
D3 has a 350K resistor to ground
connection of R15 changed  and values of that and R16 adjusted
Q7 Q8 Q9  Q10 are KSA1156 instead of  STN9360 on schematic
trimpot added to R12 for offset
Q13 collector has an added 100k 2W resistor
Edited by congo5
silkscreen reading error
