beaux Posted May 9, 2017 Report Posted May 9, 2017 Hi, Check this 12000 euro amp out. There are so many $10k amps popping out these years. They come from workshops. Actually, I doubt if they are really worth the price. (I am only able to upload 3 pics.) Angstrom Audio Laboratories is back at it again with a statement level Headphone Amplifier of uncompromising standards. MSRP $13,750. Power Output 3,5 watt per channelDual Mono Power Supplyweight 35 KgFull Regulated Power Supply 12 Tubes( 6 x channel)2 ECC802S input/driver stage per channel2 6CG7 double triode in triode composite Circlotron operatingResponse Frequency 12 hz to 150 KhzOutput is in CurrentOutput impedance 10 Ohm to 3 KohmDistorsion 1% @ 20 Hz to 20 Khz OMG! Response Frequency 12 hz to 150 Khz. Is it for human or aliens? Quote
Whitigir Posted May 9, 2017 Report Posted May 9, 2017 Doesn't matter, it look cheaper than any Chinese made at 1/10 the price internally. Quote
Craig Sawyers Posted May 9, 2017 Report Posted May 9, 2017 There is only one word for it - UGH. What a mess. Quote
Tinkerer Posted May 9, 2017 Report Posted May 9, 2017 That's a shit ton of tubes and transformers. Looks like a mainframe module from 1956. Quote
justin Posted May 9, 2017 Report Posted May 9, 2017 i like the look of it. if that's a modushop enclosure as someone else said, they did a damn good job of styling and photography. would need to see it in person next to something like a Nagra. the perf board internals are weird though. even if building a one-off you'd be better off etching a copper board or using a blank single sided board. the tolerances on those perf boards are usually really bad and i'd be very worried about the possibilities of shorts or arcing with high voltage Quote
spritzer Posted May 9, 2017 Report Posted May 9, 2017 When you say it, that looks like a steel Modushop chassis with a new top plate and wooden side panels. Cheapest possible crap then... The perf boards are just retarded. I mean why would you do that, there is no good way to mount the tube sockets compared to a proper pcb with large slots to securely mount them. Ohhh and a RK27 volume control in a 12000€ amp? Are you fucking kidding me? 1 Quote
swt61 Posted May 9, 2017 Report Posted May 9, 2017 7 hours ago, beaux said: Hi, Check this 12000 euro amp out. There are so many $10k amps popping out these years. They come from workshops. Actually, I doubt if they are really worth the price. (I am only able to upload 3 pics.) Angstrom Audio Laboratories is back at it again with a statement level Headphone Amplifier of uncompromising standards. MSRP $13,750. Power Output 3,5 watt per channelDual Mono Power Supplyweight 35 KgFull Regulated Power Supply 12 Tubes( 6 x channel)2 ECC802S input/driver stage per channel2 6CG7 double triode in triode composite Circlotron operatingResponse Frequency 12 hz to 150 KhzOutput is in CurrentOutput impedance 10 Ohm to 3 KohmDistorsion 1% @ 20 Hz to 20 Khz OMG! Response Frequency 12 hz to 150 Khz. Is it for human or aliens? Read your welcome PM. It'll save you a lot of grief. Not a great first post! Quote
Whitigir Posted May 9, 2017 Report Posted May 9, 2017 I think this unit is Dillan unit from Head-fi ? Possibly Quote
Hopstretch Posted May 9, 2017 Report Posted May 9, 2017 Nah they backed out of the deal for him to review it. Quote
DefQon Posted May 9, 2017 Report Posted May 9, 2017 That's a non production prototype unit. The Angstrom stuff sound pretty good. Didn't Nick have a custom headamp built by these guys back in the days on the other site to drive his R10's? Quote
