starcat Posted January 23, 2021 Report Posted January 23, 2021 Thread seems to be dead, all builders left 🙂 Quote
mwl168 Posted January 23, 2021 Report Posted January 23, 2021 The original design of Blue Hawaii uses 2SK170 BL grade which has the IDSS grade in the same range of LSK389B. Double check the data sheet to confirm. 2SK170/LSK389 are JFET so using either 10K or 50K volume pot should be fine. 10K pot may be more ideal if your source can drive it. 1 Quote
mwl168 Posted February 28, 2021 Report Posted February 28, 2021 Switched from Megatron to the Blue Hawaii this morning. Different sound signature but equally as satisfying. This one is not the BJT version but the one that uses 2SK216/2SJ79 with cascoded CCS and adjustable plate current.  4 Quote
audiostar Posted April 9, 2022 Report Posted April 9, 2022 Very interesting, someone here is calling the BH an "Orpheus clone"... @kevin gilmore Quote
kevin gilmore Posted April 9, 2022 Report Posted April 9, 2022 that person is a moron. the orpheus has 3 capacitor coupled stages. the BH is completely dc coupled. 4 Quote
chinsettawong Posted April 10, 2022 Report Posted April 10, 2022 Maybe he was referring to the DIY headphones he was testing. Quote
spritzer Posted April 10, 2022 Report Posted April 10, 2022 Yeah, those are the one Milos was working on. Quote
simmconn Posted January 26, 2023 Report Posted January 26, 2023 TL; DR: I’ve wanted to build a Blue Hawaii ever since I read about it on head-wize. I finally got around building a mini BH-BJT packed into a small enclosure like a can of sardines. Many small tweaks were done in attempt to reach the measured performance of the original Blue Hawaii. The details of the journey are recorded here. Many thanks to Dr. Kevin Gilmore for designing this legendary project. Thanks to Kerry, JimL, Joamat and many others for making it such a fun journey. KGBH1.pdf 14 Quote
JoaMat Posted January 26, 2023 Report Posted January 26, 2023 Jolly good work! Thank you for the excellent PDF document. Lots of interesting stuff there. 1 Quote
MLA Posted May 3, 2024 Report Posted May 3, 2024 On 1/26/2023 at 9:20 AM, simmconn said: Many small tweaks were done in attempt to reach the measured performance of the original Blue Hawaii. Working on a BH at the moment, and given what you found regarding Cob for 2690; do you think it would be worthwhile to use TTC004b instead, or is the difference too small? I guess you may have checked it but discarded it as an option?  Quote
Helium Posted May 5, 2024 Report Posted May 5, 2024 On 5/3/2024 at 9:57 AM, MLA said: Working on a BH at the moment, and given what you found regarding Cob for 2690; do you think it would be worthwhile to use TTC004b instead, or is the difference too small? I guess you may have checked it but discarded it as an option?  Seems that KSA1220AYS may also be replaced with TTA004B,Q? The latter also seems better. Quote
hyperma Posted December 23, 2024 Report Posted December 23, 2024 The 2SC5460B is back, renamed as TTC5460B, a TO-126 packaged 2SC6127 given us more possibilities on construction, maybe it's time to start a new project? Quote
Helium Posted yesterday at 02:50 PM Report Posted yesterday at 02:50 PM Did anyone experience that BH BJT is quieter than other Stax amps? Like 15 o'clock vs 12-13 o'clock on T2. Is there any way to increase gain? Quote
jamesmking Posted 7 hours ago Report Posted 7 hours ago (edited) 20 hours ago, Helium said: Did anyone experience that BH BJT is quieter than other Stax amps? Like 15 o'clock vs 12-13 o'clock on T2. Is there any way to increase gain? As far as I know most of Kevin's valve and value/transistor hybrids aim for a gain of 1000x - thats what the mostly modern T2 has and I think the blue BJT blue Hawaii. The only exception I have experienced is the (standard) EL34 Megatron which has lower gain. Edited 7 hours ago by jamesmking Quote
