Craig Sawyers Posted June 28, 2019 Report Posted June 28, 2019 (edited) Are those transmitter tubes in the Moth amps? Edited June 28, 2019 by Craig Sawyers Quote
Dusty Chalk Posted June 29, 2019 Report Posted June 29, 2019 Radar tubes And it’s not even an amp, it’s a night light. (Actually it’s more of a conversation piece, and that conversation usually has the phrase, “good lord!” declared at some point.) Quote
Voltron Posted June 29, 2019 Report Posted June 29, 2019 No, Dusty, those are not the Moth night lights, those are Moth M-304-TL power amplifiers. Moth Audio web site (May 19, 2010): 35 watt single-ended class A1 no feedback interstage transformer coupled monaural amplifier. Specifications: Topology: One triode for voltage gain, transformer coupled to the output power triode. Only thermionic devices and magnetic circuits are used. No coupling capacitors and no feedback. The output power triode never leaves class A, operation and is used at half its rated plate dissipation for longer life. Tubes: Four 6D22S rectifier "Svetlana" (Russian) One 5Y3 rectifier "Sovtek" (Russian) One 5842Q voltage gain & driver "Sylvania" (USA) One 304TL output "Imac" (USA) Wiring: Hand wired point to point for all circuits. Cardas solder user throughout. Capacitors: Polypropylene in soybean oil for power supply circuits. Output Transformers: Custom manufactured for Moth Audio Corporation. User selectable: 2,4,8, & 16 Ohms. Connectors: Cardas rhodium plated RCA for unbalanced input, Neutrik gold plated XLR for balanced input. Silver-plated speaker connectors. Chassis: Zinc plated 18-gauge, cold rolled steel with a heavy wrinkle black powder coating. Polished and black anodized 3/16" thick aluminum top and bottom plates. Brass plaques are custom etched and filled. Indicator pins are 24K gold plated. Glass Bell Jars: .25" thick hand blown Pyrex with acid etched logo. Power Output: 45 watts, 5% THD @ 1kHz. Total Harmonic Distortion: Less than 1% 40 - 20 kHz @ 35watts. Power Supply: Low-flux leakage design using toroidal power transformers as well as toroidal inductors. Frequency Response: (-3dB Points) 10Hz - 40 kHz . Input Sensitivity: 1.5V for 35 watts out. Input Impedance: 100k ohms unbalanced. 600 ohms balanced. Power Requirements: 105 - 125 VAC 60Hz (210 - 250 VAC 50Hz.) 400 Watts. Dimensions: 20"H x 15.75" W x 23" L Weight: 75 Lbs. Warranty: All components carry a 3-year parts and labor warranty. Tubes carry the manufacturers' warranties. 4 1 Quote
Craig Sawyers Posted June 29, 2019 Report Posted June 29, 2019 That is a totally insane tube! https://frank.pocnet.net/sheets/140/3/304TL.pdf . 3 Quote
Torpedo Posted July 7, 2019 Report Posted July 7, 2019 I have no idea how the Phonitor sounds and if it's worth the price of admission, but it's one of the coolest with all the pots and the VU meters. Quote
RudeWolf Posted July 7, 2019 Report Posted July 7, 2019 Supposedly starting from Phonitor 2 they're really good. XE has the same amp topology, but with a proper balanced output. The inner signal paths are SE, as doing a balanced X-feed matrix would cost a fortune. 1 Quote
Knuckledragger Posted July 19, 2019 Report Posted July 19, 2019 Trio KA-7500 paired with KEF 303s. Quote
Knuckledragger Posted July 23, 2019 Report Posted July 23, 2019 (edited) ~$7 lbs, ~$19,000 Quote iPhone XS Max £1100 Astell&Kern Ultima SP1000 DAP £2500 Unknown (DAP?) Unknown (battery pack?) Mass Kobo 404 balanced amp £1500 Chord Hugo DAC £1800 Sony WM1Z DAP £2500 Mysphere 3 headphones £3000 Grado PS2000E headphones £2700 iPhone: 7.34oz A&K SP1000: 13.64 oz Mass Kobo: 22.9281 oz Chord Hugo: 15.8 oz Sony WM1Z: 16.05 oz Mysphere 3.2: 11.9931 oz Grado PS2000E: 24.7 oz Edited July 23, 2019 by Knuckledragger The WYSIWYG editor is a steaming pile. 1 Quote
EdipisReks1 Posted July 23, 2019 Report Posted July 23, 2019 2 hours ago, Knuckledragger said: ~$7 lbs, ~$19,000 It's been done, and better. 2 2 Quote
Dusty Chalk Posted July 23, 2019 Report Posted July 23, 2019 5 hours ago, Knuckledragger said: ~$7 lbs, ~$19,000 He even got the optimal headphone haircut. Quote
Grahame Posted July 23, 2019 Report Posted July 23, 2019 3 hours ago, EdipisReks1 said: It's been done, and better. Ah, 240p Memories ... Where Are They Now? 3 2 Quote
skullguise Posted July 24, 2019 Report Posted July 24, 2019 I remember that, and the battery-powered T-Amp to drive them! used to own that pairing myself..... Quote
Pars Posted July 24, 2019 Report Posted July 24, 2019 (edited) You know it's serious with cable lifters... Edited July 24, 2019 by Pars Quote
skullguise Posted July 25, 2019 Report Posted July 25, 2019 ^^^ Those Dali's should be in Speaker Porn....I've liked some of the sound I've heard from that small dome mid and ribbon tweeter of theirs.... Quote
