Thanks @luvdunhill! I'm using the buffer with the ubal/bal board which have a 1.3kohm resistor to ground on the output so i don't think an additional resistor is necessary. Plus I already have the PCBs and the pins match.
I am interested in buffers for another project though. Ill let you know.
cspirou: I would add an input resistor to ground as well. You can match Q1 to Q3 and Q5 to Q7, but I don’t think matching is all that useful here. If you want to try another small SMD buffer, let me know. I have just ordered some boards now that I have verified their performance versus sims.
I can include matched Toshiba JFETs and the other dual package BJTs are available at Mouser.
Those look pretty sweet Marc!
  • 4 weeks later...
On 1/20/2017 at 9:59 AM, kevin gilmore said:
it had better look like this
the output impedance is about 1k, working on the diamond buffer output now
I'm going to order the transistors for this and the buffers.
1. I know that I have to match for hfe and Vbe but do I match all the N together and the P together or do I match N to P?
2. The highest hfe is the BC546\556 C, this only comes with formed leads.  Will I need to straighten them out, and if so I'm guessing there's no issue with that?
2 hours ago, sbelyo said:
I ordered BC546B\556B  I couldn't find the C for both.  Anybody see a problem with the B?
C has the highest hFe. B might be okay if you measure a bunch and take the highest measuring ones. It seems to be in stock here:
https://www.tme.eu/en/details/bc556c-dio/pnp-tht-transistors/diotec-semiconductor/bc556c/?utm_source=octopart.com&utm_medium=cpc&utm_campaign=compare-2018-01
https://www.rocelec.com/part/FAIFSCBC556CBU
I haven't ordered from either place so I don't know what they are like.
That first place had them both...  Darn, guess I didn't search hard enough.  I ordered 250 each of the B from arrow and a transistor tester off ebay.  We'll see what kind of numbers I get.
I’d match for hFE, but also try to get Vf (also known as Vbe) as close as possible as well. I’d shoot for 5% if possible. Matching the N and P is often nigh impossible depending on device type. You just have to do the best you can.
BTA is the newer B designation.
Just wondering if MPSA06/56 could be used in place of these? Pinout is backwards (EBC vs. CBE for BCs).
