kevin gilmore Posted August 3, 2016 Report Posted August 3, 2016 40? that scares me unless you are using it to drive speakers. even then its a bit much default gain is 10 Quote
purk Posted August 3, 2016 Report Posted August 3, 2016 I would go between 6 or 8. This works well for my lower impedance Sony headphones all the way to Hifiman HEK. Quote
jowls Posted August 3, 2016 Report Posted August 3, 2016 9 minutes ago, kevin gilmore said: 40? that scares me unless you are using it to drive speakers. even then its a bit much default gain is 10 I thought that seemed odd. As tempting as this is I have emailed @spritzer to see if he has anything suitable at the moment. I live a long way from a post office, which is a long way from anywhere else, so life gets expensive when things go boom... Quote
JimL Posted August 30, 2016 Report Posted August 30, 2016 On August 3, 2016 at 1:23 PM, kevin gilmore said: 40? that scares me unless you are using it to drive speakers. even then its a bit much default gain is 10 Yep, usual gain for SPEAKER amps is around 10-20 (20-26 dB). Headphones generally need less, which is why in the bad old days the headphone jacks on integrated amps and receivers often had a resistor in series to cut down the gain, and possibly also to prevent the amp from blowing out the headphones. Quote
