9 minutes ago, kevin gilmore said:
40?
that scares me unless you are using it to drive speakers. even then its a bit much
default gain is 10
I thought that seemed odd. As tempting as this is I have emailed @spritzer to see if he has anything suitable at the moment. I live a long way from a post office, which is a long way from anywhere else, so life gets expensive when things go boom...
  • 4 weeks later...
On August 3, 2016 at 1:23 PM, kevin gilmore said:
40?
default gain is 10
Yep, usual gain for SPEAKER amps is around 10-20 (20-26 dB).  Headphones generally need less, which is why in the bad old days the headphone jacks on integrated amps and receivers often had a resistor in series to cut down the gain, and possibly also to prevent the amp from blowing out the headphones.
Register a new account
Sign in
