kevin gilmore Posted June 25, 2016 Report Posted June 25, 2016 (edited) so yesterday this showed up quoting alex... "In a nutshell, the Liquid Carbon is a fully-discrete, fully-balanced, transportable solid-state headphone amplifier that is capable of driving all but the most demanding of headphones - delivering satisfying levels and offering superb driver control for exceptional detail and linearity." lets run that thru fact check for a second. yep... "Liar Liar Pants on Fire" fully balanced? nope, not in the way that any truly differential amplifier would be. (like any of the super symmetry variants) and absolutely no common mode rejection. fully-discrete? nope not really, see the single ended to balanced converter in the schematic below http://gilmore.chem.northwestern.edu/lc.pdf so much fail in one package... can the stax mafia do better, you betcha. board in progress now, will run up to +/-24V and bolt to a heatsink. So say a liquid gold clone for about $300 in parts. people, why do you buy poorly built crap like this. Buy Schiit, or Audio-GD or many other high quality brands for a lot less money. Edited June 25, 2016 by kevin gilmore 7 Quote
wink Posted June 25, 2016 Report Posted June 25, 2016 (edited) Not excactly Nelson Pass, is it..? Perhaps it wuz designed by Di Arrhoea.... Edited June 25, 2016 by wink Quote
spritzer Posted June 25, 2016 Report Posted June 25, 2016 This really should be called Liquid Shit as two Schiit Modi amps are much better than this. Far cheaper too... Quote
kevin gilmore Posted June 25, 2016 Author Report Posted June 25, 2016 (edited) in progress Edited June 25, 2016 by kevin gilmore 2 Quote
JimL Posted June 25, 2016 Report Posted June 25, 2016 3 hours ago, spritzer said: This really should be called Liquid Shit as two Schiit Modi amps are much better than this. Far cheaper too... Actually, there is a lot of carbon in poo. 1 Quote
UFN Posted June 25, 2016 Report Posted June 25, 2016 Interesting work Kevin/Birgir (as always when something new comes out ) Can I start by making a passionate plea for enlarging the board a bit so that tombstoning the resistors isn't necessary? //UFN Quote
kevin gilmore Posted June 25, 2016 Author Report Posted June 25, 2016 (edited) But but but so tiny... the resistors are currently .4 inch and the verticals are .2 inch this is the first of many boards. Due to stuff in the middle, .4 resistors are going to make the board much bigger. almost liquid gold bigger. Oops what do you want for 6 hours total. and its schiit magni uber updated board picture above board is 3.85 x 2.5 inches definitely the .47 ohms have to be made bigger, because the current surface mount ones are blowing up Edited June 25, 2016 by kevin gilmore Quote
MLA Posted June 26, 2016 Report Posted June 26, 2016 9 hours ago, UFN said: Interesting work Kevin/Birgir (as always when something new comes out ) Can I start by making a passionate plea for enlarging the board a bit so that tombstoning the resistors isn't necessary? //UFN Or go surface mount if/where power handling requirements allow? I'm really impressed by the level of tininess and with GRLV singles, this would be a very compact amp. Quote
kevin gilmore Posted June 26, 2016 Author Report Posted June 26, 2016 and it will sound a whole bunch better due to the power supply input fets no longer available as to92, so they are now sot23 may be the reason the liquid gold was canceled as that used to92 input transistors. Quote
kevin gilmore Posted June 26, 2016 Author Report Posted June 26, 2016 bigger version, most resistors .5 inch and laying down 3.85 x 3 Quote
UFN Posted June 26, 2016 Report Posted June 26, 2016 Excellent. Looks worth the extra 1/2" of board to me //UFN Quote
MLA Posted June 26, 2016 Report Posted June 26, 2016 3 minutes ago, UFN said: Excellent. Looks worth the extra 1/2" of board to me //UFN Okay then... Quote
kevin gilmore Posted June 26, 2016 Author Report Posted June 26, 2016 (edited) much more better version now above. fets on the back side. just about 100% groundplane its about $15 per channel could use the caddok resistors for the .47 ohm, and double the price of the amplifier Edited June 26, 2016 by kevin gilmore 2 Quote
wink Posted June 27, 2016 Report Posted June 27, 2016 Think about it, if Cavalli worked for Schiit, and Cavalli means horse...... Well, you make the connection.... (With sincere apologies to Jason Stoddard & Mike Moffat, and all the other denizens of Schiit Audio)..... Quote
kevin gilmore Posted June 28, 2016 Author Report Posted June 28, 2016 what is likely the final version posted including board file. actually performs better with bipolar outputs. Quote
spritzer Posted June 28, 2016 Report Posted June 28, 2016 Of course it does, we don't need no stinkin' mosfets!! Quote
wink Posted June 28, 2016 Report Posted June 28, 2016 (edited) Do you think we should go for a move back to germanium transistors? I mean, if you want distortion in your amp, you want it to sound good. (Let's hope Cavalli doesn't find out about 'em) https://robertkeeley.com/2013/09/germanium-transistors/ Edited June 28, 2016 by wink Quote
kevin gilmore Posted June 28, 2016 Author Report Posted June 28, 2016 absolutely we need to cryo all parts. Quote
Arthrimus Posted June 28, 2016 Report Posted June 28, 2016 Don't forget to cryo the source too. Everyone knows that 1s and 0s only sound their best after they've been exposed to -190c temperatures. Quote
JimL Posted June 29, 2016 Report Posted June 29, 2016 15 hours ago, spritzer said: Of course it does, we don't need no stinkin' mosfets!! MOSFETs work great! As current sources. 1 Quote
wink Posted June 29, 2016 Report Posted June 29, 2016 I tried to cryo my ears, but I got a cold reception from the people who do it. So, I'm going with having my ear canals quantum tunnelled to cut out the different propagation delays at varying frequencies..... This is akin to reducing the jitter in your DAC, but a much better high tech solution....... It also helps eliminate the Josephson Junction noise in your synapses and the sound of quantum foam. 2 Quote
spritzer Posted June 29, 2016 Report Posted June 29, 2016 7 hours ago, JimL said: MOSFETs work great! As current sources. I know... Quote
kevin gilmore Posted June 29, 2016 Author Report Posted June 29, 2016 mosfet current sources are depletion mode. made a very different way from enhancement mode mosfets. Quote
kevin gilmore Posted July 6, 2016 Author Report Posted July 6, 2016 updated board, one of the fets was labeled wrong Quote
