naamanf Posted February 25, 2021 Report Posted February 25, 2021 Ping ponged up a set of Naval Aviator wings and broke in one of my SurfPreps. 8
n_maher Posted February 25, 2021 Report Posted February 25, 2021 57 minutes ago, Voltron said: Impressive shit man. Yeah, this. Not that it's unexpected given the amps that you used to build back in the day. 1 1
swt61 Posted February 25, 2021 Report Posted February 25, 2021 (edited) That looks like it'll attract a lot of flying seamen! Edited February 25, 2021 by swt61 1 1
VPI Posted February 25, 2021 Report Posted February 25, 2021 Stopped the cabinet project to complete the build and do the Ng 5 Cut Test for the Cross Cut Sled. Based on the accuracy with no adjustment, I am guessing I did it wrong or did not do a long enough 5th cut. 2
swt61 Posted February 25, 2021 Report Posted February 25, 2021 12" wide, 6 quarter Walnut shelves for a Milo & Otis kitchen remodel. 3
dsavitsk Posted February 25, 2021 Report Posted February 25, 2021 5 hours ago, VPI said: Based on the accuracy with no adjustment, I am guessing I did it wrong or did not do a long enough 5th cut. A broken clock is still correct twice a day 🙂 Really, if you did the initial alignment with a good square, there's no reason you wouldn't get it right on the first shot. 2
naamanf Posted February 25, 2021 Report Posted February 25, 2021 7 hours ago, VPI said: Stopped the cabinet project to complete the build and do the Ng 5 Cut Test for the Cross Cut Sled. Based on the accuracy with no adjustment, I am guessing I did it wrong or did not do a long enough 5th cut. Looks good, mine also came out close enough that I didn’t have to adjust it.
VPI Posted February 26, 2021 Report Posted February 26, 2021 (edited) Determined that no matter how many tools you buy from Kreg to support the Pocket Hole when tightening, it is a bitch to get a square box with that twisting motherfucker holding everything together. I had the stupid clamps in every other hole and still have to set up ten other clamping systems to keep everything from twisting with the first screw. This is expounded greatly when trying to use the Micro one with 1/2” BB drawers. Edited March 2, 2021 by VPI
dsavitsk Posted February 26, 2021 Report Posted February 26, 2021 I've tried every shortcut to making bb drawers, from pocket holes to dominos to biscuits. In the end, I found that an actual joint was both faster and more accurate than any of them. And more satisfying. And probably stronger. 4
swt61 Posted February 26, 2021 Report Posted February 26, 2021 Yep. That locking rabbit joint is about the next best thing to a dovetail joint. That being said, I've built enough pocket screwed drawers to have learned the idiosyncrasies. Nothing like experience on that front. 1
VPI Posted February 26, 2021 Report Posted February 26, 2021 I decided to ditch the Kreg and pre-ordered this fancy one with more vertical orientation and supposedly less annoyance. https://castleusa.com/products/castle-110-pocket-cutter.html 1
swt61 Posted February 26, 2021 Report Posted February 26, 2021 (edited) Obviously you didn't scroll down their web page enough to see the one that even inserts the screws. It's a paultry $57,000. Edited February 26, 2021 by swt61 1
dsavitsk Posted February 26, 2021 Report Posted February 26, 2021 7 hours ago, swt61 said: 12" wide, 6 quarter Walnut shelves for a Milo & Otis kitchen remodel. What are you planning to use to hang them?
Voltron Posted February 26, 2021 Report Posted February 26, 2021 21 minutes ago, dsavitsk said: What are you planning to use to hang them? 5
VPI Posted February 27, 2021 Report Posted February 27, 2021 On 2/25/2021 at 7:24 PM, dsavitsk said: I've tried every shortcut to making bb drawers, from pocket holes to dominos to biscuits. In the end, I found that an actual joint was both faster and more accurate than any of them. And more satisfying. And probably stronger. Went and picked up the router and table saw equipment to try building these joints on each. Went to put the Jessem Micro Fence Adjust on my table to find the Amazon seller did not include the screws and I am too lazy to figure out Dado blades tonight so I guess the drawers will wait.
VPI Posted February 28, 2021 Report Posted February 28, 2021 Threw together a scrap wood shooting board for the 62. Did the whole Rob Cosman build with the tape to keep glue up from warping the mdf. Seemed to work well. 6 1
VPI Posted March 1, 2021 Report Posted March 1, 2021 (edited) After several redesigns during construction I ended up with a multi-use storage cart. Need to finish it off with some French cleats on each side and decide if I Arm-R-Seal it or just use Shellac like the MDF top. Decided it needed more bling so added some Zebrawood holders and Woodpecker stuffs. Edited March 1, 2021 by VPI 6
jose Posted March 2, 2021 Report Posted March 2, 2021 Yesterday I received a Proxxon 28566 base for mini tool (I normally use a dremel 4000 and a Bosch GRO12v-35) ). I thought it was better than the Dremel base, in fact Proxxon uses better materials and has a reputation for making high quality mini tools, but I was disappointed. Although the materials are much better than the Dremel (It´s made of aluminum and steel and Dremel use plastic), the guides are "crooked", so that when lowering and raising the tool, it is locked in any position. I have tried unscrewing the guides, but have not gotten a proper tool movement. I'm going to see how to modify it. 🙄 1
VPI Posted March 3, 2021 Report Posted March 3, 2021 Local shop got the big Milwaukee routers back in stock. Worthy upgrade over the 2 1/4 Bosch that seems to be working fine?
naamanf Posted March 3, 2021 Report Posted March 3, 2021 15 minutes ago, VPI said: Local shop got the big Milwaukee routers back in stock. Worthy upgrade over the 2 1/4 Bosch that seems to be working fine? I’m sticking with the Bosch until I have a reason to upgrade to something more substantial.
jose Posted March 3, 2021 Report Posted March 3, 2021 A few minutes after work with the vertical drill...
swt61 Posted March 3, 2021 Report Posted March 3, 2021 (edited) Jeff, I have the same ridgid sanding center. It's on of a few tools that survived hurricane Harvey. It's a nice little tool. Edited March 3, 2021 by swt61
naamanf Posted March 3, 2021 Report Posted March 3, 2021 2 minutes ago, swt61 said: Jeff, I have the same ridgid sanding center. It's on of a few tools that survived hurricane Harvey. It's a nice little tool. I’ve been happy with it as well. Seems to be pretty popular, there are about 5 other similar sanders but the Rigid seems to be the best of the group.
