VPI Posted February 8, 2021 Report Posted February 8, 2021 Okay, Rockler has all three (PCS, Contractor and Jobsite Pro) in stock. For someone that works maybe a weekend a month on projects, am I getting enough benefit from the PCS over the others to give up all the extra space in the garage?
dsavitsk Posted February 8, 2021 Report Posted February 8, 2021 I don't think the PCS really takes up any more room than the contractor saw.
VPI Posted February 8, 2021 Report Posted February 8, 2021 It actually takes less. I had the Contractor Saw with the 36” T-Glide ready to go but at 400+ lbs I am not sure I would ever get it out of the back of the Audi. Think I am going cheap and getting the crappy Jobsite Pro.
dsavitsk Posted February 8, 2021 Report Posted February 8, 2021 The contractor saw should still be fine for most purposes. And if it isn't, resale will be easy. That said, several vendors will ship the larger ones on a lift gate for free.
naamanf Posted February 8, 2021 Report Posted February 8, 2021 (edited) 1 minute ago, dsavitsk said: The contractor saw should still be fine for most purposes. And if it isn't, resale will be easy. That said, several vendors will ship the larger ones on a lift gate for free. Make sure you get the industrial base, Jeff. Edited February 8, 2021 by naamanf
naamanf Posted February 8, 2021 Report Posted February 8, 2021 1 minute ago, VPI said: No I got the super cheap one. Don’t get the industrial base then, it won’t fit.
VPI Posted February 8, 2021 Report Posted February 8, 2021 I am sure it is going to suck, but I could not come up with 60” of space in the single car space with all the crap I already have.
naamanf Posted February 8, 2021 Report Posted February 8, 2021 21 minutes ago, VPI said: I am sure it is going to suck, but I could not come up with 60” of space in the single car space with all the crap I already have. I bet it will be better than you think. Just make sure you spend 95.95% of your timing setting it up 😉. 1
VPI Posted February 8, 2021 Report Posted February 8, 2021 Going to take some serious planning just to get this little fucker in here.
VPI Posted February 8, 2021 Report Posted February 8, 2021 I think it might fit here, and there is no fucking way I would have been able to drag the contractor saw at 430 lbs out of the back of the fucking Audi. 1
VPI Posted February 9, 2021 Report Posted February 9, 2021 Opened up the box enough to see it all feels super cheap and cheesy. Going to take it back and rethink this. 2
naamanf Posted February 9, 2021 Report Posted February 9, 2021 (edited) Cut to length and straight lined to parallel 200bf of walnut. I think I need to find a better supplier and get FAS select. Less work for me and I’ll just carry over the added expense to the customer. Edited February 9, 2021 by naamanf 4
Dusty Chalk Posted February 10, 2021 Report Posted February 10, 2021 Decided to learn some from the theatrical activity known as "pipe and drape" and frame out supports for the mattresses with PVC. Did the math and realized the queen was pretty close to the hypotenuse of the two twins (yeah, I know that's a double-entendre waiting to happen, go ahead), but after looking at them, decided the triangle would be too claustrophobic, so going to make a trapezoid. It's just a matter of what material to use for the fourth wall/door (yes, you too, can make a movie pun). Probably woolen drapes or something.
VPI Posted February 10, 2021 Report Posted February 10, 2021 Decided to keep the crappy table saw short term as the addition to the house is going to have to be done with the extra 3 car garage to fit the big saw I want. Got the Incra mitre gauge thing which I am not terribly impressed with as two of the three mitre rail tightening screws will not turn at all so the thing cannot be tightened in the mitre slots. The Sawstop seems to be decent outside of the top, it scratches every time something touches it. Hopefully the construction happens quickly so I can trash this thing. Going to try to make a usable sled to do some cuts tomorrow at some point.
naamanf Posted February 10, 2021 Report Posted February 10, 2021 2 minutes ago, VPI said: Decided to keep the crappy table saw short term as the addition to the house is going to have to be done with the extra 3 car garage to fit the big saw I want. Got the Incra mitre gauge thing which I am not terribly impressed with as two of the three mitre rail tightening screws will not turn at all so the thing cannot be tightened in the mitre slots. The Sawstop seems to be decent outside of the top, it scratches every time something touches it. Hopefully the construction happens quickly so I can trash this thing. Going to try to make a usable sled to do some cuts tomorrow at some point. Looks good, I’m guessing it will work better than you expect, except when you have to cut thicker dense hardwood. Then like Doug mentioned, go to a thin kerf blade.
luvdunhill Posted February 10, 2021 Author Report Posted February 10, 2021 Looks good, I’m guessing it will work better than you expect, except when you have to cut thicker dense hardwood. Then like Doug mentioned, go to a thin kerf blade. What if you need to cut some Hot Dogs though?
naamanf Posted February 10, 2021 Report Posted February 10, 2021 3 minutes ago, luvdunhill said: What if you need to cut some Hot Dogs though? I picked one of these up. https://www.webstaurantstore.com/bizerba-vs-12-d-v-1-13-vertical-feed-automatic-meat-slicer-1-2-hp-120v/256VS12DV1A.html 1
Emooze Posted February 10, 2021 Report Posted February 10, 2021 This would also be an option. https://daisous.com/collections/n03_cutting-utensils/products/4994163294818
swt61 Posted February 10, 2021 Report Posted February 10, 2021 ^ No Sir, it would not. It doesn't have a power cord! 1
luvdunhill Posted February 10, 2021 Author Report Posted February 10, 2021 Incra doesn’t have an attachment for either and the ping-pong table wouldn’t work. Perhaps the Goldfinger is the logical choice, assuming no dangerous outgassing.
VPI Posted February 10, 2021 Report Posted February 10, 2021 Went through the rudimentary setup for the Jobsite Pro. Got most things straight except the fence is not 90 degrees to the table and that is not something they seem to allow you to adjust.
Grahame Posted February 10, 2021 Report Posted February 10, 2021 31 minutes ago, luvdunhill said: Incra doesn’t have an attachment for either and the ping-pong table wouldn’t work. Perhaps the Goldfinger is the logical choice, assuming no dangerous outgassing. The cut doesn't look all that clean .. 1
