naamanf Posted May 13, 2021 Report Posted May 13, 2021 It mounts to the spindle and has a dust extractor line hooked up to it. Catches all the chips when you are machining.
naamanf Posted May 14, 2021 Report Posted May 14, 2021 No more collet wrenches or resetting zero. Next up, fully automated tool changes. IMG_4403.MOV 4 1
swt61 Posted May 14, 2021 Report Posted May 14, 2021 Pretty badass. How many ebony penis extensions can you make in a day?
luvdunhill Posted May 14, 2021 Author Report Posted May 14, 2021 16 minutes ago, swt61 said: Pretty badass. How many ebony penis extensions can you make in a day? Depends how much he dicks around. 4
Grahame Posted May 17, 2021 Report Posted May 17, 2021 Meanwhile ... The next step in Head Case stick smashing vertical integration? https://www.npr.org/2021/05/17/996913329/as-lumber-prices-climb-diy-ers-cut-out-the-middle-man-and-mill-their-own 1
Voltron Posted May 17, 2021 Report Posted May 17, 2021 Saw G-Man's post a minute after my brother emailed an article about how the the 400% rise in lumber prices is putting a damper on surging home building in the Bay Area. If only Stretch had some flat land available on the Rancho... 1
Grahame Posted May 18, 2021 Report Posted May 18, 2021 ^ https://www.nbcnews.com/politics/white-house/should-joe-biden-worry-about-soaring-lumber-prices-n1267475
swt61 Posted May 19, 2021 Report Posted May 19, 2021 Does that mean he gets two pensions? Also, did you take that picture with your drone? 1
naamanf Posted May 19, 2021 Report Posted May 19, 2021 20 minutes ago, swt61 said: Does that mean he gets two pensions? Also, did you take that picture with your drone? Two different people. No, but I had to hold the phone over my head. Those are 20”x15” 1
Augsburger Posted May 20, 2021 Report Posted May 20, 2021 Speaking of wood. What would you recommend for treating teak patio furniture. Cleaning and oiling our teak furniture is becoming an annual chore. The only product they stock anywhere in town is Watco Teak finish and I really don't care for the results.
swt61 Posted May 21, 2021 Report Posted May 21, 2021 Anything you use is going to require regular maintenance, due to your location. A marine varnish is your best bet.
Voltron Posted May 21, 2021 Report Posted May 21, 2021 https://www.solventfreepaint.com/linseed_varnish.htm Add Gelomat if you want a more matte finish. 1
swt61 Posted May 21, 2021 Report Posted May 21, 2021 ^ I couldn't remember the name. Excellent product.
luvdunhill Posted May 21, 2021 Author Report Posted May 21, 2021 Started with this then made it look like this then decided to play with chemicals then made it look like this via a probably Doug approved implement called a card scraper, then put the first coat on! probably will do another coat, might sand between coats? I am not sure what is recommended with this Osmo stuff… But; it looks ok! - I found out that if you get bubbles in the epoxy it’s doesn’t quite work to just put another layer on top. Also the really shallow flaws didn’t hold the epoxy well. I kinda wanted a contrasting jet black color in the various cracks and crannies and it looks pretty decent! There were some knotholes that went all the way through the plank and those took the epoxy really well. 13
Voltron Posted May 21, 2021 Report Posted May 21, 2021 Nice! Steve and I used a torch to draw up the air bubbles in the epoxy and that works well. I really didn't like Osmo but it looks good there. I bought this Woodpeckers Super Fence months ago, received the package weeks ago, opened it finally last week to find out they sent only a single piece of Super Track by mistake. They sent me the actual fence and I got to keep the super track for my trouble. Anyway, this went together very easily, and now I have to set up another router to rout my router table. This very meta effort will create channels for the tracks to hold the Super Fence. 9
dsavitsk Posted May 21, 2021 Report Posted May 21, 2021 (edited) 41 minutes ago, luvdunhill said: via a probably Doug approved implement called a card scraper, then put the first coat on! I love card scrapers. Different brands have different hardnesses, and work better for different applications. I have both Veritas and Lie Nielsen. The veritas are a little harder and hold an edge better, the LN are a little softer and a little gentler and seem less likely to tear out across the grain. Both are super useful. And cheap. Also, Crucible for avoiding sharp corners. Edited May 21, 2021 by dsavitsk 2
swt61 Posted May 21, 2021 Report Posted May 21, 2021 Marc, that is awesome! Al, very nice fence. Doug, thanks.
naamanf Posted May 22, 2021 Report Posted May 22, 2021 Looks like y’all got some fun projects going. Before I could do anything else I need some HVAC in the shop since it’s getting hot and humid. Put this 26,000 BTU Mr Cool in yesterday/today. Pretty darn easy DIY install. So far it’s cooling great. 8
Voltron Posted May 23, 2021 Report Posted May 23, 2021 Now the Super Fence has tracks and locks down solidly. 6
luvdunhill Posted May 23, 2021 Author Report Posted May 23, 2021 (edited) On 5/21/2021 at 5:01 PM, Voltron said: Nice! Steve and I used a torch to draw up the air bubbles in the epoxy and that works well. I really didn't like Osmo but it looks good there. I tried the heat gun in the picture but the issue was the bubbles were inside the fill and the heat gun made the epoxy look scorched. Oh well, only one fill in the end had bubbles. When I tried to put another layer on top, it didn’t bind well. And when I scraped it, the entire second coat came off… This was the TopOil which is a lot thinner than the Polyx. It’s a very odd substance, it is very hydrophobic - very hard to get off your hands with water. I also in testing found the directions on the can didn’t work as well. I ended up applying the first coat pretty thick with a synthetic pad. In my tests that worked better than the usual thin rubbed on coat. I haven’t been back to check on it but hopefully will get to it later this week. Edited May 23, 2021 by luvdunhill
naamanf Posted May 24, 2021 Report Posted May 24, 2021 Opening the hospital back up to the public next week, so I was commissioned to make some receptionist shields. 7
