naamanf Posted February 1, 2021 Report Posted February 1, 2021 Re-did the lettering on the bottom. 9 Quote
naamanf Posted February 1, 2021 Report Posted February 1, 2021 2 minutes ago, swt61 said: Looks great! Thanks. So much to learn, so little time. No intentions of become a sign maker but it’s a little fun. 1 Quote
n_maher Posted February 1, 2021 Report Posted February 1, 2021 13 hours ago, naamanf said: Gag sign for a friend whose wife caught herself on fire while cooking. Learn something every time. Should have used a bolder font. Tip for the future, in case this isn't what you did to fix it, but if you're v-carving and finding that you aren't getting a "bold" enough result a quick attempt at a fix is to simply cheat Z zero down a bit (experiment, it's easy to go too deep in a hurry) and then rerun that section of the program. I've found it works acceptably well without butchering the tapered sections. One other option is to rerun the program with a 90d V as opposed to a 60d, but that only works if your first effort was with a 60d bit. 1 Quote
naamanf Posted February 1, 2021 Report Posted February 1, 2021 1 minute ago, n_maher said: Tip for the future, in case this isn't what you did to fix it, but if you're v-carving and finding that you aren't getting a "bold" enough result a quick attempt at a fix is to simply cheat Z zero down a bit (experiment, it's easy to go too deep in a hurry) and then rerun that section of the program. I've found it works acceptably well without butchering the tapered sections. One other option is to rerun the program with a 90d V as opposed to a 60d, but that only works if your first effort was with a 60d bit. Exactly what I did basically. Set the start depth at .0015. All done with a 90. 1 Quote
VPI Posted February 1, 2021 Report Posted February 1, 2021 Spent way too much time trying to chisel out a space for the hinges for the box but now that it is done, I think they look too small. 1 Quote
naamanf Posted February 1, 2021 Report Posted February 1, 2021 (edited) Using the router and cleaning the edges with the chisel would be the faster method. White side even makes a corner chisel. Looks good to me though. I’m also no expert, but I think you might be using the wrong chisel. Edited February 1, 2021 by naamanf Quote
VPI Posted February 1, 2021 Report Posted February 1, 2021 They make some chisel with arms to make it easier but all the YouTube guys used what appeared to be regular chisels. You just make a whole bunch of slits and then come in from the side and clear them all out. Quote
dsavitsk Posted February 1, 2021 Report Posted February 1, 2021 Router is overkill for such small hinges. But a router plane is a good option. As is a mortise plane. Quote
VPI Posted February 2, 2021 Report Posted February 2, 2021 Yes, that’s the one with the arms, but Rockler was out of stock. I have found that Boiled Linseed Oil hates residual wood glue and I am going to need to do some serious sanding before the next round. Really digging how the BLO does with the Mahogany. 8 Quote
naamanf Posted February 2, 2021 Report Posted February 2, 2021 11 minutes ago, VPI said: Yes, that’s the one with the arms, but Rockler was out of stock. I have found that Boiled Linseed Oil hates residual wood glue and I am going to need to do some serious sanding before the next round. Really digging how the BLO does with the Mahogany. Looks great! Quote
dsavitsk Posted February 2, 2021 Report Posted February 2, 2021 I find card scrapers more effective for removing glue residue that sandpaper. Or chisels. 3 Quote
Fitz Posted February 2, 2021 Report Posted February 2, 2021 45 minutes ago, dsavitsk said: overkill Now you're just making up words. 1 1 Quote
VPI Posted February 2, 2021 Report Posted February 2, 2021 19 minutes ago, dsavitsk said: I find card scrapers more effective for removing glue residue that sandpaper. Or chisels. Yep. I meant to grab one of those when I was out. Quote
swt61 Posted February 2, 2021 Report Posted February 2, 2021 I think those hinges look just right. I wouldn't go bigger. Looks great. Have you figured out why they call it Zebrawood? Because it smells like a herd of Zebras pissed on it when you cut it. Quote
Dusty Chalk Posted February 2, 2021 Report Posted February 2, 2021 I need ideas on how to hold up a floppy queen mattress that is being repurposed as a wall in a vocal booth. I also have two twin mattresses that will make up two of the other walls. All three are hard foam. Any ideas? Quote
naamanf Posted February 2, 2021 Report Posted February 2, 2021 1 minute ago, Dusty Chalk said: I need ideas on how to hold up a floppy queen mattress that is being repurposed as a wall in a vocal booth. I also have two twin mattresses that will make up two of the other walls. All three are hard foam. Any ideas? Build a frame with cross braces in the back and contact cement it to the frame. not sure I would want to be in an enclosed area with someone’s old mattresses though 🤮 1 Quote
blessingx Posted February 2, 2021 Report Posted February 2, 2021 Haven't thought about Silence of the Lambs in a while. 1 Quote
Dusty Chalk Posted February 2, 2021 Report Posted February 2, 2021 2 hours ago, naamanf said: not sure I would want to be in an enclosed area with someone’s old mattresses though 🤮 They’re all mine, but yeah, agreed, I will be vacuum cleaning them thoroughly. Also: thanks! Quote
blessingx Posted February 2, 2021 Report Posted February 2, 2021 Any chance there are easier options or at least sillier options? Quote
VPI Posted February 2, 2021 Report Posted February 2, 2021 I really do not see that doing anything but creating serious suck-outs and accents across the spectrum Dusty. Easier to buy proper insulation OC-703 and build frames around them and hang them at reflection points. Quote
naamanf Posted February 2, 2021 Report Posted February 2, 2021 Put up some overhead board storage. 10 Quote
VPI Posted February 3, 2021 Report Posted February 3, 2021 You need more sticks. It appears the only model of Laguna bandsaw available before the middle of the year is the little 14/Twelve or whatever. Might actually be better as it is fairly small, but does not have some of the fancy brakes and stuff of the slightly more expensive models that are on long back order. Quote
Voltron Posted February 3, 2021 Report Posted February 3, 2021 I know you like things but do you need a bandsaw right now? Quote
VPI Posted February 3, 2021 Report Posted February 3, 2021 Not necessarily. I have two 12” sticks that I wanted to split in two to make a pair of 24” side tables and I have some crooked line shit I want to do. My main thought is that the cheap Laguna is probably more than I need so there is no reason to wait months for something with an additional option or two. Quote
