swt61 Posted January 19, 2021 Report Share Posted January 19, 2021 What's the medium? Maple? Quote Link to comment Share on other sites More sharing options...
naamanf Posted January 19, 2021 Report Share Posted January 19, 2021 3 minutes ago, swt61 said: What's the medium? Maple? MDF. Not wasting wood until I have it exactly like I want it.Ā 2 Quote Link to comment Share on other sites More sharing options...
Voltron Posted January 20, 2021 Report Share Posted January 20, 2021 That's some nice whittling! Quote Link to comment Share on other sites More sharing options...
n_maher Posted January 20, 2021 Report Share Posted January 20, 2021 Very cool, Naaman, looking forward to seeing the progress.Ā Ā 1 Quote Link to comment Share on other sites More sharing options...
Kerry Posted January 20, 2021 Report Share Posted January 20, 2021 All this CNCing got me excited, so I figured Iād share... Hereās my mill and this is a heat sink that I am thread milling. Ā Very cool stuff IMG_2788.MOV Also, Iāve been using painters tape and super glue instead of fixtures. Works great on metal. So much easier.Ā 10 Quote Link to comment Share on other sites More sharing options...
Kerry Posted January 20, 2021 Report Share Posted January 20, 2021 Hereās an example of me milling some small brackets without having to worry about the outer contours Ā 6 Quote Link to comment Share on other sites More sharing options...
naamanf Posted January 20, 2021 Report Share Posted January 20, 2021 32 minutes ago, Kerry said: Hereās an example of me milling some small brackets without having to worry about the outer contours Ā Good to know that trick works with aluminum as well. As I understand it there is a bit to get thread cutting to work? Quote Link to comment Share on other sites More sharing options...
Kerry Posted January 20, 2021 Report Share Posted January 20, 2021 (edited) Yes.Ā I got these two thread mills: #4-40 #6-32 and #8-32 Took a bit of work to get the bit setup correctly in Fusion360, but works great now.Ā When you're ready to try them, I can help you out. Edited January 20, 2021 by Kerry 1 Quote Link to comment Share on other sites More sharing options...
naamanf Posted January 21, 2021 Report Share Posted January 21, 2021 Iām not sure if my setup can do threadĀ milling, not sure if itās a controller or spindle limitation.Ā Ā Rough draft finished. Time to get some thicker cheap wood for a full mock up.Ā Ā 10 Quote Link to comment Share on other sites More sharing options...
VPI Posted January 21, 2021 Report Share Posted January 21, 2021 That is pretty fucking impressive.Ā Ā As I do not have one of these nerd drills like everyone else, my projects are sloppier and much less impressive.Ā Ā Ā That is pretty fucking impressive.Ā Ā As I do not have one of these nerd drills like everyone else, my projects are sloppier and much less impressive.Ā Ā Ā 2 Quote Link to comment Share on other sites More sharing options...
naamanf Posted January 21, 2021 Report Share Posted January 21, 2021 18 minutes ago, VPI said: That is pretty fucking impressive.Ā Ā As I do not have one of these nerd drills like everyone else, my projects are sloppier and much less impressive.Ā Ā Ā That is pretty fucking impressive.Ā Ā As I do not have one of these nerd drills like everyone else, my projects are sloppier and much less impressive.Ā Ā Ā I almost feeling like Iām cheating at this point.Ā Drawing some obscure shape, loading some wood, hitting run, and poof! Magic. Ā 1 Quote Link to comment Share on other sites More sharing options...
VPI Posted January 21, 2021 Report Share Posted January 21, 2021 Do you even get out of your recliner at this point? Quote Link to comment Share on other sites More sharing options...
naamanf Posted January 21, 2021 Report Share Posted January 21, 2021 2 minutes ago, VPI said: Do you even get out of your recliner at this point? Not until I can get sheet goods with legs.Ā 2 Quote Link to comment Share on other sites More sharing options...
Kerry Posted January 21, 2021 Report Share Posted January 21, 2021 59 minutes ago, naamanf said: Iām not sure if my setup can do threadĀ milling, not sure if itās a controller or spindle limitation.Ā Ā Rough draft finished. Time to get some thicker cheap wood for a full mock up.Ā Ā Thatās very impressive! Thread milling is more about the rigidity of the mill. At that size Iām not sure how well it would work, but it might be worth a try. I run my spindle at 12k rpm. Other than that itās just a program/speeds/feed.Ā 2 Quote Link to comment Share on other sites More sharing options...
VPI Posted January 21, 2021 Report Share Posted January 21, 2021 Decided to try to build a hand plane holder and āoverāĀ practice makingĀ pocket holes.Ā Ā 2 Quote Link to comment Share on other sites More sharing options...
luvdunhill Posted January 21, 2021 Author Report Share Posted January 21, 2021 How quaint.Ā Quote Link to comment Share on other sites More sharing options...
swt61 Posted January 21, 2021 Report Share Posted January 21, 2021 17 hours ago, naamanf said: I almost feeling like Iām cheating at this point.Ā Drawing some obscure shape, loading some wood, hitting run, and poof! Magic. Ā Did someone say poof? Quote Link to comment Share on other sites More sharing options...
VPI Posted January 22, 2021 Report Share Posted January 22, 2021 As it appears that the big Milwaukee router will be out of stock forever, what is another HC approved router table router I can grab for short or long term? Quote Link to comment Share on other sites More sharing options...
dsavitsk Posted January 22, 2021 Report Share Posted January 22, 2021 Doubt it matters much. I think I have a dewalt in mine. Also, shouldn't a shelf for a hand plane utilize said plane during the construction? Quote Link to comment Share on other sites More sharing options...
naamanf Posted January 22, 2021 Report Share Posted January 22, 2021 26 minutes ago, VPI said: As it appears that the big Milwaukee router will be out of stock forever, what is another HC approved router table router I can grab for short or long term? I have the Bosch, ordered the Milwaukee and a week later told it was actually back ordered. I had the Bosch in my last router table and have no complaints.Ā Quote Link to comment Share on other sites More sharing options...
VPI Posted January 22, 2021 Report Share Posted January 22, 2021 29 minutes ago, dsavitsk said: Doubt it matters much. I think I have a dewalt in mine. Also, shouldn't a shelf for a hand plane utilize said plane during the construction? I only used the block plane to put a tiny chamfer on the edges I think. Ā I have not even figured out how to use the adjustment doohickeys on that one yet. Ā 25 minutes ago, naamanf said: I have the Bosch, ordered the Milwaukee and a week later told it was actually back ordered. I had the Bosch in my last router table and have no complaints.Ā Is that the Bosch with 2 1/4 and wooden handles? Quote Link to comment Share on other sites More sharing options...
naamanf Posted January 22, 2021 Report Share Posted January 22, 2021 15 minutes ago, VPI said: I only used the block plane to put a tiny chamfer on the edges I think. Ā I have not even figured out how to use the adjustment doohickeys on that one yet. Ā Is that the Bosch with 2 1/4 and wooden handles? Correct.Ā Quote Link to comment Share on other sites More sharing options...
swt61 Posted January 23, 2021 Report Share Posted January 23, 2021 I would buy a 3 1/4 hp router. In a router table you're likely to want to use large bits at times, and the 3 1/4 hp motor is much more robust. The Bora Porta-mate gets good reviews.Ā Quote Link to comment Share on other sites More sharing options...
Augsburger Posted January 23, 2021 Report Share Posted January 23, 2021 My feelings exactly. Quote Link to comment Share on other sites More sharing options...
naamanf Posted January 23, 2021 Report Share Posted January 23, 2021 23 minutes ago, swt61 said: I would buy a 3 1/4 hp router. In a router table you're likely to want to use large bits at times, and the 3 1/4 hp motor is much more robust. The Bora Porta-mate gets good reviews.Ā Iām holding out for the Red smasher.Ā Quote Link to comment Share on other sites More sharing options...
