Senes Posted March 17, 2016 Report Posted March 17, 2016 Hello! I'm going to acquiere a stax srm-3 wired in 117v (originally 100v) Could you please tell me how can I switch it to 230v (France) ? Thanks you un advance! Quote
Craig Sawyers Posted March 17, 2016 Report Posted March 17, 2016 Unless anyone has any specific advice, take the lid off and photograph what you see and post it. Or try head-fi rather than head-case. Quote
spritzer Posted March 17, 2016 Report Posted March 17, 2016 Here you go: 100v: Gray+White White wire from the ACplug+Brown+Green 117v: Gray+White White wire from the AC plug+Blue+Purple 240v: Blue+White wire from the AC plug Purple+Gray Quote
DefQon Posted March 18, 2016 Report Posted March 18, 2016 (edited) Actually the SRM-3 has a vertical raiser PSU PCB with the transformer directly soldered. You need to desolder the grey wire from the 100 or 117v position (comes from the switch or fuse) and that goes to the 230v pad and then solder the centre windings from 0 to 120v for dual primary 240v AC input. I wouldn't be surprised if you have a completely different transformer in the amp though. Edited March 18, 2016 by DefQon Quote
Senes Posted April 14, 2016 Author Report Posted April 14, 2016 http://www.noelshack.com/2016-15-1460655465-img-20160414-193433.jpghttp://www.noelshack.com/2016-15-1460655463-img-20160414-193503.jpghttp://www.noelshack.com/2016-15-1460655464-img-20160414-193513.jpg Here I took some photos, I do not see any "230v pad", only 0; 120 and 100 Could you give me some indications please ? Quote
spritzer Posted April 14, 2016 Report Posted April 14, 2016 They are split primaries so you need to wire them in series or in parallel. See the wires going from 0 to 0 and 120 to 120? Remove both and solder just a link between the 0 and 120 in the middle, i.e. change from parallel to a series setup. Quote
