Took my Cary 300sei out of the garage not heated where it has been  unused for over a year, amp was pretty cold temps in the high 40s.
I should have let it get to room tempature but I didn't Amp turned on got a hum from the transformers I really never noticed before,Input tubes light up but My WE300bs never  light up.
Ideas? I have another set of we300bs ,but I don't want to take a chance installing them. I don't have any cheaper tubes to try.
Open it up and see if there is anything amiss?  I think the tubes are AC heated in the 300sei so they should work unless the transformer is busted.  Edit:  Light up that is.
Edited by spritzer
I just looked at the internal pics I have of the stock 300SEI and the heaters for the 300B's are bad...real bad.  They are just a tap off the transformer, fed through a diode bridge and into the tubes.  Quite possibly the worst way to do this.
my 300sei went silent years ago - (blew a resistor).  I replaced it - and it blew again - so that was not the issue. -- I have not gotten back to it...  (and you Don't want to see the inside of this thing.. ooph)..
I would give Cary support a call as well - the people I talked to years ago were very nice and helpful (at the time).
good luck.
Or get in contact with Dennis Had directly via his email and see if he can give some pointers on troubleshooting/what is wrong. He did so with a few Cary products that went south that I owned years back.
